How to swap a B18 motor in a 92 civic vtec
Old Sep 30, 2009 | 09:30 PM
Manny 77's Avatar
Default How to swap a B18 motor in a 92 civic vtec
I need to know how to wire the b18 motor in a civic With a d16 engine?? (its a 92 civic Dx OBD1 BUT I HAVE A VTEC D16 ENGINE IN IT) also if i can use the p28 muhen ecu that i got?? What tranny im going to need the cable one or the hydraulic one??? i was looking at a 94 integra and all the engine plugs are the same on a d16 engine but im not sure what i going to need if i do the swap so if anyone have done this swap before please let me Know what i going to need and how to do it.. also what axles i need??? and motor mounts??? in fact from 0 to 100, begginig to end please....
Old Sep 30, 2009 | 10:30 PM
K20egcw's Avatar
Default Re: How to swap a B18 motor in a 92 civic vtec
Everything from an Integra will plug and play as far as motor swap and suspension. Your gonna need b series axles, shift linkage, wire harness, the ecu should be alright if its chipped, and of course the motor/trans, stock b series mounts will work as well. Like I said all the stuff you need you can get off an integra. As far as wiring vtec, your car already has it so if you have a vtec b series motor/wire harness/ecu everything should work.
barzano724
Nov 12, 2013 08:50 AM
93CivNewB18
Dec 5, 2008 02:47 PM
mrod1985
Feb 18, 2008 02:25 PM
hizroyalty
Mar 20, 2006 05:09 PM
SlapHappyPappy
Mar 18, 2004 12:19 PM
