IAT sensor removal
so how to i get these bolts off without stripping...
i'm thinking impact screwdriver.
confirm?
update: confirmed. just picked one up at the store and worked like a charm
confirm?
how big was it? i'm having the same issue getting that dam thing off. I already stripped one of my bolts I think I need to pull the manifold off now to fix it
Use locking pliers like above noted. Anymore I don't even try to loosen them with a screwdriver, I just go straight to the vice-grips and then run the screw out with a screwdriver. Pretty much any small screw in the engine bay I do that with.
ya, I think i'm going to just pull the manifold off. I believe this is the culprit of my idle hunt, because I just noticed one of the screws is broken off inside of there.
came that way from japan, idk. lame tho for sure.
vader007
Feb 16, 2017 10:07 PM
