normal operating temperature?
Old Aug 28, 2002 | 01:33 PM
ED8DX's Avatar
Default normal operating temperature?
It's summer as we all know it is hot in the southwest. About two months ago I flushed the coolant system and wired the fans to a manual switch. I replaced the no-name thermostat for a honda one (190 degress is when it is completely open i think). I also installed a temp gauge on the water neck where the purge plug was.
Today while driving around in 102 degree heat and other days when the temp is lower, the car levels of to about 195*. After some stop and go driving, or hard driving it slowly begins to creep up. I usually turn on the fan as soon as it hits 205*. Here is the thing, the factory temp gauge will stay at a constant level (its range is something like cold warm hot. hot being above 220* i think) but the temp gauge i installed will either go up some or will stay at 205*.
Could it be that the header is radiating enough heat that it is affecting the sending unit and heating it up. Or could the fan and the heated air it is blowing affecting the sending unit. Or when I previously flushed the cooling system could it have released some debris? thanks
[Modified by ED8DX, 3:38 PM 8/28/2002]
[Modified by ED8DX, 6:10 PM 8/28/2002]
Old Aug 28, 2002 | 02:01 PM
ED8DX's Avatar
Default Re: normal operating temperature? (ED8DX)
ttt
Old Aug 28, 2002 | 09:31 PM
ED8DX's Avatar
ttt last time.
Old Aug 28, 2002 | 10:26 PM
LsDXRacer's Avatar
I thought the normal apperating temp. is around 170-180
BTW what dose "ttt" tand for?
**EDIT**
i learned to read and seen you were from Texas... Im from southern Cali. next to the beach where it almost never reaches above 80*
[Modified by LsDXRacer, 11:30 PM 8/28/2002]
Old Aug 29, 2002 | 04:35 AM
keithv's Avatar
Default Re: normal operating temperature? (LsDXRacer)
the stock gauge is an idiot gauge. it has a range of temperature that it will see but not change its movement. the ordinary person wants to see a gauge not move at all whereas us car enthuiast want to know where the temp is acurrately at.
so i think your aftermarket gauge is working just fine.
Old Aug 30, 2002 | 02:49 AM
Mista Bone's Avatar
D Tranny Guru
your new temp gauge is working normally. Stock gauge doesn't MOVE when water temps are 160 to 220.
I just installed a AutoZone 170 degree stat, normal water temp at cruising is dead on 180 degrees. Car will heat up to 210 in traffic, then the fan kicks on.
My old stock stat gave same temps as you listed.
Old Sep 1, 2002 | 06:41 PM
ED8DX's Avatar
Default Re: normal operating temperature? (Mista Bone)
Well I figured out why it was heating up. While I was in line at a drive thru, I noticed even with my fans on it was still heating up. It got to about 250* and was idling funny. I checked out the wiring and I had one of the fans polarity incorrect. Stupid me, I am glad it didn't turn out to be an expensive mistake.
[Modified by ED8DX, 8:44 PM 9/1/2002]
Old Sep 1, 2002 | 06:49 PM
bfrank81's Avatar
BTW what dose "ttt" stand for?
I'm wondering the same thing??
Old Sep 1, 2002 | 07:51 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: normal operating temperature? (bfrank81)
stands "for to the top". ok, so 180 is a normal temp and 205 is when the fans should kick on, but what is the temp where its tooo hot, and you may blow a headgasket or something??? thanx
Old Sep 1, 2002 | 09:45 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: normal operating temperature? (mannyman)
If you see ANYTHING abve 210, turn the heater on and get moving or shut engine off.
slowman's Avatar
I took way too long
he means, 'to the top' . used to 'bump' up a post 'to the top' of the forum so it gets attention.
Old Sep 2, 2002 | 12:58 PM
mannyman's Avatar
Default Re: normal operating temperature? (slowman EF)
yeah what he said. And thanx mista, thats exactl what i wanted to know
manny
eddie7978
Mar 22, 2018 08:33 AM
agb22
17
Mar 7, 2017 07:11 AM
Shidou
Sep 16, 2016 06:49 AM
danno33
Jul 15, 2009 07:26 AM
dc4b20
Nov 24, 2007 11:26 AM
