00 Civic - Where does hose for FUEL INJECTION AIR (FIA) CONTROL SYSTEM connect?
Old Sep 29, 2009 | 06:18 PM
EGfosho's Avatar
OG Tech
Default 00 Civic - Where does hose for FUEL INJECTION AIR (FIA) CONTROL SYSTEM connect?
Hello, did a search but no luck. The engine is 2000 D16y8 and I have this hose that connects to the Air Assist Solenoid Valve(#24 in the picture). I was wondering where does it connect to?
Old Sep 29, 2009 | 06:24 PM
Former User's Avatar
Default Re: AIR ASSIST SOLENOID VALVE hose
Old Sep 29, 2009 | 06:40 PM
EGfosho's Avatar
OG Tech
Thanks for the picture, but now I am kinda confuse. lol. I must have the wrong intake pipe... There is that hole where the pipe/hose from the valve cover goes into and the plug. I don't see another hole or nipple on the intake for that FIA or AASV hose
Old Sep 29, 2009 | 06:55 PM
You have the correct intake. The breather hose connects to the intake nipple to the right of the receptacle for the electrical plug and the FIA hose connects to the intake nipple to the left of the receptacle for the electrical plug (not visible in your picture).
Old Sep 29, 2009 | 07:26 PM
EGfosho's Avatar
OG Tech
Nope, just one nipple right from the receptacle. So, I guess I need to find an intake pipe with two nipples and one receptacle.
Old Sep 29, 2009 | 07:28 PM
skaternak's Avatar
there should be 3, i have a 2000 civic ex also, d16y8 and i have 3 you have the wrong pipe
Old Sep 29, 2009 | 07:30 PM
You must have an intake from a 96-98 D16Y8 engine. You need one from a 99-00.
Old Sep 29, 2009 | 07:32 PM
EGfosho's Avatar
OG Tech
I see, cool. Thanks for the help. Time to visit the wrecking yard again.
Old Sep 29, 2009 | 07:36 PM
The intake pipe on my 00 Civic EX D16Y8 has 2 hose nipples and one IAT receptacle. Is that what you are saying?
Old Sep 29, 2009 | 07:37 PM
skaternak's Avatar
yes
Old Sep 29, 2009 | 07:40 PM
yes
Old May 2, 2012 | 05:16 PM
alexcivicd15b99's Avatar
I have a 99 civic ex with a skunk2 intake manifold.. I have a similiar problem related to the fiac valve that hopefully someone can anwser for me please..I cnt seem to find what hose I'm supposed to tap into with a vacuum tee.. I need to find where the hose that comes out of the top of fiac valve belongs.. I know the stock manifold has an inlet between the two middle runners bt on the skunk2 they eliminated it.. so my main concern is where can I attach it to so that I can pass my smog cuz of of now it shows that its been tampered with...
Old Jun 1, 2012 | 11:20 PM
Rudy N Alvarez's Avatar
what about the M/T housing doesn't have the air assist solenoid valve hose can you run a A/T car with out the air assist soleniod valve i just saw the diagram and i think i want to run it with out it and i was wondering
Old Jun 2, 2012 | 07:59 PM
EGfosho's Avatar
OG Tech
If the skunk 2 eliminates it, then you are **** out of luck. lol. Usually smog places doesn't take the visual inspection serious. As long it doesn't have a CEL and the numbers are good. you should be fine. Just cap it.
Old Jun 2, 2012 | 08:00 PM
EGfosho's Avatar
OG Tech
Why would you want to do this...?
Old Jun 4, 2012 | 08:08 PM
b/c the damn thing is 127 and i got the other thermostat housing unit with out the slot for the air assist solenoid and figured i can pull intake off at a junk yard or find one on craigslist and not have to worry about that part but i am not to sure if it is going to work out tho
Old Feb 16, 2013 | 03:14 PM
gagnier27's Avatar
Default Re: 00 Civic - Where does hose for FUEL INJECTION AIR (FIA) CONTROL SYSTEM connect?
hello i am looking for this part, where i can buy any? cheaper ofcoruse, i was looking in all junkers here in tampa, and i can not fine nothing, all honda civic vehicles do not have engine, regards
Old Feb 16, 2013 | 04:22 PM
HondaPartsHero's Avatar
Technical Hero
Honda is pretty much the only one that makes it that I can find. So your only other options is find one on Craigslist on a part out car, ebay, or the marketplace.
Old Feb 17, 2013 | 06:41 AM
gagnier27's Avatar
thanks a lot bro,,
Old Feb 17, 2013 | 07:32 AM
EGfosho's Avatar
OG Tech
This website might have it.
http://www.hondaautomotiveparts.com/
Old Feb 17, 2013 | 08:14 AM
Technical Hero
It does have it and its about $75 before shipping
freydaddy
11
Aug 9, 2010 04:49 PM
Project22a
Oct 25, 2007 09:28 AM
nhanimator
Jul 10, 2006 02:49 PM
mugenspoongsr
Jul 1, 2005 08:35 PM
Ocloren
Jun 23, 2005 04:07 AM
