Classic Hondas All Pre-1988 Hondas.
86 crx si zc dohc vac advance to electric
Old Sep 29, 2009 | 05:07 PM
nightlife88's Avatar
Default 86 crx si zc dohc vac advance to electric
k so i have a dohc jdm zc and i am using a vac advance distributor and here is my problem i need to have a electric advance distributor maybe of the 88-89 integra not sure if it will fit. need help wich distributor shoed i get and is it straight forward to wire up here is what i am running..... dohc zc- t3/t4 turbo ebay-450cc bluetop dsm inj.-walbro 255 lph fuel pump-
and pm6 ecu that is chipped by xenochron to run everything i have.... i was running a acura pg7 without the turbo just fine but now with the turbo have to use the pm6 but need electric advance to have everything to run right... thanks for your help
Old Sep 29, 2009 | 07:18 PM
simpletuning's Avatar
Default Re: 86 crx si zc dohc vac advance to electric
if you go to rpr they have some posts about using a prelude dizzy.. i think from the '87 or it could be an '88 prelude.. go there to check..
Old Sep 29, 2009 | 08:29 PM
night's Avatar
that would be the 88-91 with the B20A, they have that same setup of separate dist and sensor 'pod'.
the 87 and back are vacuum, as well as 86-89 accords.
Old Sep 30, 2009 | 12:29 PM
what about the 88-89 integra distributor will that fit that was my first thought.
TCHondaMan
Jan 3, 2007 06:55 PM
TURTLE_GRIP
Dec 27, 2006 08:55 PM
roterx7
Feb 18, 2006 03:16 PM
h22_crx
Oct 6, 2005 11:16 AM
wronghand
Oct 10, 2001 09:31 PM
