86 crx si zc dohc vac advance to electric
k so i have a dohc jdm zc and i am using a vac advance distributor and here is my problem i need to have a electric advance distributor maybe of the 88-89 integra not sure if it will fit. need help wich distributor shoed i get and is it straight forward to wire up here is what i am running..... dohc zc- t3/t4 turbo ebay-450cc bluetop dsm inj.-walbro 255 lph fuel pump-
and pm6 ecu that is chipped by xenochron to run everything i have.... i was running a acura pg7 without the turbo just fine but now with the turbo have to use the pm6 but need electric advance to have everything to run right... thanks for your help
Re: 86 crx si zc dohc vac advance to electric
if you go to rpr they have some posts about using a prelude dizzy.. i think from the '87 or it could be an '88 prelude.. go there to check..
that would be the 88-91 with the B20A, they have that same setup of separate dist and sensor 'pod'.
the 87 and back are vacuum, as well as 86-89 accords.
h22_crx
10-06-2005 11:16 AM
