couple questions, 2001 stock gsr what color wire is the power wire for cd deck?
Old Sep 29, 2009 | 05:06 PM
Gant's Avatar
Default couple questions, 2001 stock gsr what color wire is the power wire for cd deck?
i have two questions
1. what color wire is the power wire for the stock acura cd deck
2. im using my STOCK deck and adding subs/amp,this picture i can use my speakers to power this amp right? the part of amp that says "speaker level input"
Old Sep 30, 2009 | 12:38 AM
White95SiHB's Avatar
Default Re: couple questions, 2001 stock gsr what color wire is the power wire for cd deck?
I think it's the yellow w/red stripe.
There should be a label on the stock deck that shows which pin is the +12volt ignition wire, then you just look at the harness and match the pin to the wire.
Old Sep 30, 2009 | 05:53 AM
fcm's Avatar
fcm
Old Fart
http://www.installdr.com/Harnesses/HA-Wiring.pdf
Your 01 GSR may still have the 1986 - 1997/98 plug, either way it will be the yellow/red for switched power. 94
Old Sep 30, 2009 | 08:04 AM
mrdeadman's Avatar
They let me pick
You can use the speaker level inputs but supposedly they are not as clean as running an loc.
Old Sep 30, 2009 | 04:49 PM
audioroach's Avatar
ummm Its just as clean as running a LOC (line output converter) because its is a LOC,
Please IIRC some MTX amps have a smart turn on feature...it will turn the amp on once it "sees" signal on those lines. check with the manufacture to be sure.
smartguysjt
Dec 17, 2010 08:06 AM
1 Cam Wonder
Audio / Security / Video
Dec 20, 2004 11:02 AM
mkil5
Jul 13, 2004 04:24 PM
PearlWhiteAccord
Jun 18, 2002 05:17 AM
SonicGSR
Jun 5, 2002 05:38 PM
