distributor adjusting
Old Sep 29, 2009 | 04:40 PM
wesk18's Avatar
Default distributor adjusting
by changing the position of the distributor my car became slugish(retard) than before, it used to take off good now its slugish. my mechanic adjusted by turning clockwise(retard).
when is recommended to replace the distributor rotor and cap?
adjusting the distributor for a better peformance is this accomplish or not possible ??
Old Sep 29, 2009 | 05:12 PM
GhostAccord's Avatar
Default Re: distributor ??
Here is a link for you.
http://auto.howstuffworks.com/ignition-system4.htm
Read through the following links at the top of the linked page.
1. Introduction to How Automobile Ignition Systems Work
2. Ignition System Timing
3. Spark Plug
4. Ignition System Coil
5. Ignition System Distributor
6. Distributorless Ignition
Old Sep 30, 2009 | 03:34 AM
hondamark35's Avatar
Default Re: distributor adjusting
i can't recall if there is a point in the maintenance schedule for cap and rotor replacement, but i don't think there is. they aren't too expensive so if a visual inspection of them shows signs of wear, personally i would replace them.
adjusting it to the "right" timing will give you the best performance. by this i mean adjusting it to service sandards. you won't find 5hp advancing the timing on a computer controlled engine... if that's what you were hoping for.
***let me add that that's for a stock motor (stock internals, no forced induction). modified, dyno tuned cars can make more power with timing adjustments.
Old Sep 30, 2009 | 04:14 PM
wesk18's Avatar
thanks bro..!
RSX2SIcivic
Oct 27, 2008 11:08 PM
b16hatche
Dec 14, 2005 07:31 PM
coupon
Feb 23, 2005 07:47 AM
dlric
Dec 13, 2001 03:55 AM
