P1337 Crank Angle Sensor after engine swap
Old Sep 29, 2009 | 03:27 PM
92integraVTECgsr's Avatar
Default P1337 Crank Angle Sensor after engine swap
I just put a OBD2 B18B from a 99 Integra into a 98 Integra GSR shell. I pulled the engine from a 96 Integra LS and it was fine no codes.
Now it has this code P1337 which is the crank angle sensor. I'm puzzled. The only thing I can think of is that the GSR engine harness has the crank angle sensor going into the 4th plug coming from the ECU harness since there is a 4th plug on the ECU harness where as the LS ECU harness has 3 plugs.
Any help? I'm gonna check the helms.
Old Jan 10, 2014 | 11:10 AM
Nick Durkin's Avatar
Default Re: P1337 Crank Angle Sensor after engine swap
I have this same exact problem. What was the solution?
Old Mar 31, 2014 | 01:46 PM
Ravenous117's Avatar
Did you guys figure out the issue? I am throwing the same code with an engine swap.
Old Mar 31, 2014 | 02:24 PM
94rs-turbo's Avatar
http://ff-squad.com/wp/?p=309
Search young padawan
4drboostking
May 19, 2015 02:37 AM
silver ek
Sep 5, 2005 08:03 AM
