wiring problems out the ass
Old Sep 29, 2009 | 12:32 PM
skata89's Avatar
Default wiring problems out the ***
ill give you guys the whole story from start to end. i blew up my gsr and built the bottom end for boost, all the wiring before was fine and now since putting the motor back in im just having problem after problem, at first the main relay ground was bad and it was causing the relay to click when i tried to start it and the fuel pump wouldnt prime. i spliced a ground in just to see if it would work and it fired right up. now the fuel pump will not prime again, and it has no power getting to it. but the relay is not clicking like before, i have taken the dash out thinking there was a big problem with the wiring and everything seems to be okay except where there was an alarm in the car before i owned it. and when they removed it they just kinda cut everything and left the wires dangling,my question is what would make the fuel pump not get power all of a sudden
4potnick
Jul 31, 2007 09:38 PM
eleck
Dec 11, 2005 12:29 PM
cjmech
Nov 1, 2002 08:46 PM
