D15Z1 ECU
I'VE BEEN SEARCHING AROUND FOR A D15Z1 ECU BUT I HAVENT HAD NO LUCK DOES SOMEONE KNOW WHAT OTHER KIND OF ECU I CAN USE TO MAKE IT RUN RIGHT. I HAVE A 91 SI ECU ON IT RIGHT NOW AND ITS RUNING REAL BAD THANKS
91 DX HATCH
91 DX HATCH
If you want the motor to run correctly, it would be best to convert to obd1 and find a p07 ECU, which is the ECU for the d15z1 motor.
You might be able to find someone that can find a .bin and burn it for you if you decide to get a chipped p28 also.
THANKS EVERYONE I'LL SEE IF I CAN GET IT TO RUN
I ALSO HAVE A 92 TO 95 D16Z6 VTEC CYLINDER HEAD CAN I RUN THIS WITH MY 91' SI ECU AND 91' SI TRANS THAT WAY I CAN ALSO SEARCH FOR THE BLOCK AND SEE WHATS MY BEST OPTION
DaddyKin
14
Jul 12, 2011 01:52 PM
TurboBumblBee
May 29, 2003 09:12 PM
