N/a built H23, plus turbo questions
Old Sep 29, 2009 | 09:59 AM
granny racer's Avatar
Default N/a built H23, plus turbo questions
i plan on building an h23 as "you've prally all heard"
im wandering, what is too much HP put in a motor prior to a turbo, before the motor explodes
if the engine has a good CR and everything is tuned to its maximum optimality
would turboing it ADD extra horses like simple math,
or is it more complicated algebra. would it just blow a shitload of air in and not combust as fast and powerful. or add more power than it can handle and simply, be more than is even possible for any engine to handle.
or could you just adjust the psi to a smaller number than needed
[side qusetion]
i think the h23 has a cr of 9.8:1. im thinking that honda is obviously not full of idiots and this cr is good for a prelude, however, im putting it in my heavier Accord dx (four door) would a cr of 12:1 be good for my accord? too much too less, remember i want to turbo it later.
btw, sorry ima noob
still learnin everyday
Old Sep 29, 2009 | 10:51 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: N/a built H23, plus turbo questions
Generally speaking, as I'm not a turbo guy. You want a lower compression ratio for a turbo. You choose your size of one you want and get appropriate injectors/fuel pump/etc to match and keep up with it. You NEED to have a tune regardless of what anyone in the other thread said as this is how the air/fuel mixture is controlled.
The Forced Induction section I'm sure has a "Getting Started" or "FAQ" thread stickied at the top.
Old Sep 29, 2009 | 12:03 PM
do you know if the stock pistons and cylinders of an h23 will melt if i turbo it?
or should all that be replaced for sure?
and thanks. i shall read it!!
Old Sep 29, 2009 | 12:37 PM
TheCivicMafia's Avatar
CR doesnt need to me adjusted to weight of vehicle it needs to be adjusted to the motor, if i threw a h23 in a truck, i couldnt make it 20:1 wouldnt make sence, Stock CR would be okay for 6-8 PSI
Old Sep 29, 2009 | 12:50 PM
Puma909's Avatar
[side qusetion]
btw, sorry ima noob
If you are going to boost, you need a cr lower than 12:1. If it is going to be a street car you are going to need be around 8:1 to 9.5:1 CR. And if you will be running a 9.5:1 CR you better have access to a good tuner otherwise, you will have pre-ignition problems. The reason is the availability of high octane fuel which is rated at 91 or 92.
Old Sep 29, 2009 | 01:01 PM
i think my question should have been, do i need to sleeve and piston the h23 no matter what ?
options:
up the turbo psi, and risk melting the stock stuff
or sleeve and piston it now for more power (bigger bore) and still have strong new pistons to handle the turbo for later on.
and this goes back to my statement "honda is obviously not full of idiots"
idont really know if this engine even needs sleeving or bigger pistons, or even if the cr needs to be tampered with at all, it could be perfect as it is. would a larger volume piston even add that much more power than its worth??
its almost a 10:1 cr already, is that fine for a non track car?
im going for a scary dd basicaly
Old Sep 29, 2009 | 02:10 PM
alterdcreations's Avatar
A stock piston h23 could make 300hp boosted.....how much power is you goal? Then your answer can be answered
Old Sep 29, 2009 | 02:32 PM
im going to shoot for 400, i know im going to under shoot that, but a part of me thinks i have a chance of exceeding it.
as a tuboed h23 dd. how fast would that ware my motor??
Old Sep 29, 2009 | 05:18 PM
GhostAccord's Avatar
Not going to exceed 400Whp on stock internals for very long. You will need forged internals and sleeves. This thread feels like a dejavu..................
so im wanting to build a b series motor for my 95 dx.
my goal is just like 200hp, my main goal is to be able to smoke my friends stage 1 roush mustang. i wont be able to get a turbo for a while, but am i heading in the right direction with a b series???????
i heard h series loose power in the trany. i dont want to buy something that ill regret.
Your Hp goals have doubled since this post. In another two weeks you may be up to 600whp and on your way to actually knowing what it takes to get there. to research
Old Sep 29, 2009 | 05:39 PM
[side qusetion]
Actually a fully loaded Accord EX has a Gross Vehicle Weight rating of 3020lbs. As stated in the manual. The H23 Prelude weighs in at 3790lbs, also stated in the manual. Your dx Accord is even lighter @ 2822lbs.
And a 12:1 CR is not good for boost.
Old Sep 29, 2009 | 06:16 PM
no sleeves, wesico or mahle makes compatible pistons, stock or eagle rods will do....eagle rods are alot stronger.
Old Sep 30, 2009 | 08:16 AM
wow, its lighter!!!!!??? sweetness. i thought........the four doors
and alterdcreations
you talkin about golden eagle, or is eagle a different co. ?
Old Sep 30, 2009 | 08:19 AM
8VEYBEYB's Avatar
shes "prally" cheatin on you.....
sorry op had to do it.
Old Sep 30, 2009 | 08:47 AM
haha HEY!! prallys my word >
Old Sep 30, 2009 | 08:49 AM
8VEYBEYB's Avatar
haha ! good luck with the build man!! H's are the **** , H's are for people who enjoy torque lol.
Old Sep 30, 2009 | 08:58 AM
thats what she said -.-
heh
thanks man, i think this car as a whole is going to be legendary once complete ^.^
Old Sep 30, 2009 | 09:27 AM
Brad_and_the_acc's Avatar
heh
Old Sep 30, 2009 | 09:51 AM
Originally Posted by Brad_and_the_acc
hey, its my #1 fan haha
ill post some pics of what i vision for this car soon
Old Sep 30, 2009 | 01:23 PM
I shall be waiting..
Old Oct 7, 2009 | 06:36 PM
boostinlude218's Avatar
i have read through this and have a lot to pick a part. if i can remember it all. First off the CR issue... i personnally just did my h23 and have been very satisfied with my resuls. I am runnin 10.5 cr which is obviously above the stock CR. I did dayton sleeves, wiseco pistons 10.5:1, crower rods (eagle doesnt make rods for the h23 anymore). did 5 angle valves titanium valves and retainers, oversized rings. can remember any more specifics. but the general (important stuff). I am running a turbonetics 60-1 56 trim turbo. fmic standard stuff. first time to the dyno hit 356 on 11 lbs of boost. a lot lower boost then i want. Using my baby turbo till more funds.... with this build im going to run 20 lbs on a much bigger gt35r. all the people that ever say running 6-8 lbs on a stock motor are idiots. i tried it before my build. had 111000 original miles and it lasted about 10 days. so whoever says 300hp on stock motor....wrong....you'll quickly be at zero. Don waste your time and money on a turbo kit from ebay with no aftermarket inernals. Trust me!!! I may be in debt but this project was well worth hitting high 11's at the track his year. hit me with pm's please im always looking for improvements or critiques
Old Oct 7, 2009 | 07:33 PM
detailzdelivere's Avatar
you must of had either a horrible tune or a tired engine to die that fast..
did you do a compression test before the install?
Old Oct 8, 2009 | 05:35 AM
X2
Old Oct 8, 2009 | 05:24 PM
had compression test. everything checked out. Had a base tune with hondata s300 from my tuner. the base tune was the same one used after my build but obviously the stock motor didnt handle he boost well. roughly 6 lbs on the base tune. nothing too extensive done with that tune before it blew...
Old Oct 8, 2009 | 05:27 PM
also had new timing belt adjusted the valves and had new water pump and oil pump on the stock motor..... didnt make sense to me with all the other info on boosting stock motors but i very rarely if ever again will belive what people say about boosing sock motors
Old Oct 8, 2009 | 05:51 PM
K20egcw's Avatar
I personally would boost a 12.5:1 compression motor. Your car is gonna make power til your turbo spools and that compression is gonna spool your turbo alot faster as well. Low compression boost is for people that are unsure of their motor/tuner cause it gives them more room to play. If you have a good tune on your motor it'll be a monster and still be reliable
