90 Civic B16A SiR II ODB1 IACV/Idle Question - Searched
Old Sep 29, 2009 | 07:50 AM
EF7's Avatar
EF7
Default 90 Civic B16A SiR II ODB1 IACV/Idle Question - Searched
I installed a ODB1 B16A SiR II engine from a 92 EG6 into my 90 Civic Hatchback Auto.
When I fist started it, the idle was a 3,500 RPM, I cleaned the IACV and FITV and it didn't fix the issue.
Checked ECU for codes and I got 5 and 7. Fixed the vacuum routing to the MAP sensor and it helped a bit, then adjusted TPS to 0.45 closed and 4.5 wot.
ECU codes went away but now it idles at 2,000 RPM
When I cover the upper hole inside the throttle body (IACV hole) idle normalizes,
1. Is it possible for the IACV to be bad without throwing an error code on the ECU?
2. Where can I get a replacement IACV for this motor?
IACV from ODB2 B16's and B18's are different, will the IACV from a delSol Vtec work?
Thanks in advanced for any help.
Old Sep 30, 2009 | 07:51 AM
h2b_sedan's Avatar
Default Re: 90 Civic B16A SiR II ODB1 IACV/Idle Question - Searched
have you checked for other vacuum leaks. maybe your idle screw??? try that
LBREF8
Jan 6, 2010 08:55 PM
EF7
Sep 30, 2009 06:53 PM
mafay2
Jul 13, 2005 11:52 AM
6thgen4u2nv
Oct 11, 2003 08:06 AM
