OBD1 engine with OBD2 car
Old Aug 28, 2002 | 12:21 PM
vshivik's Avatar
New User
Default OBD1 engine with OBD2 car
hey. will i be able to use an obd1 engine with an obd2 ecu, provided i get an obd2 wiring harness? for example, i have a 94 gsr, going into a 2000 civic dx. would i be able to replace the gsr harness (on the engine, obd1) with my stock dx harness (obd2), and then simply add the secondary wires, like vtec, knock, etc... and use all this with an obd2 ecu?? any input would be greatly appreciated. thanks
Old Aug 28, 2002 | 12:24 PM
SpooN Man's Avatar
Default Re: OBD1 engine with OBD2 car (vshivik)
all you want to do is get an obd 1 ecu and an obd 2 to obd 1 adaptor harness
your obd 2 engine harness should plug and play - the missing obd 2 stuff.
Old Aug 28, 2002 | 12:29 PM
dubnine's Avatar
You'd have to get obd2 injectors and alternator and put a crank position sensor on the GSR motor. You will be able to use your DX harness and add the vtec wires and knock sensor wire... You'll also have to switch some stuff around on the ECU plugs and you'll need an obd2 B ecu, unless you plan on getting an adapter harness to run on obd1 ECU. If you go with an OBD1 ECU, the crank position sensor will not be needed. The CPS is not neccessary on the obd2 ecu, but without it you'll have a CEL.
JdmAcclude
Jan 8, 2012 07:26 PM
Rok_Stok
Oct 22, 2010 03:04 PM
alsxe10
10
Sep 29, 2010 07:06 PM
trevek10
Sep 17, 2009 05:28 PM
screen_name
Apr 22, 2006 06:56 PM
