HELPPPP rhd conversion in eg6 left turn does not work
Old Sep 28, 2009 | 06:50 PM
twistedimage's Avatar
Default HELPPPP rhd conversion in eg6 left turn does not work
stuff is working except for the left turn signal. the hazrds work on both sides in the rear but will not blink in the left front.
then turn on the left blinker and it will not blink. it will not blink on the dash or on the cluster as well. but the front one does. so if you have any in put please help me..
Old Sep 28, 2009 | 07:57 PM
vsmhatched's Avatar
Default Re: HELPPPP rhd conversion in eg6 left turn does not work
what wiring are you using? USDM or JDM? and what turn signal switch are you using USDM or JDM? Checked all fuses?
Old Sep 29, 2009 | 06:38 AM
using jdm wiring all around and then the usd harness in the rear. that has been repinned. and the combo switch is jdm. fuses and relays are all good
Old Sep 30, 2009 | 04:20 AM
vsmhatched's Avatar
you sure the jdm combo switch has the same pin out as the usd one? I used all usdm wiring in my rhd civic along with the usdm combo switch and everything worked out just fine. Has it ever worked normal before?
Old Sep 30, 2009 | 06:45 AM
got it figured out when i got the conversion from steve at hmotors the cut all the wiring off for the lights and they cut it so far back that the wires pulled back in the loom. and the left front turn signal for the marker light was cut by the boot. which interupts the circut. once i re conected that wire all was good. just took 2 days to figure out. gave steve a call and told him so he could prevent anyone else from having the problem.
Old Sep 30, 2009 | 03:16 PM
vsmhatched's Avatar
good to hear
Old Oct 1, 2009 | 06:37 AM
thanks man. what a pain it was
kadidle
Mar 15, 2009 09:46 AM
slvrDC4
Feb 6, 2008 08:10 PM
jdmnash
May 6, 2006 11:18 AM
CRseXxy
Mar 18, 2005 03:57 PM
