OBD1 JDM P72 Auto to manual
Old Sep 28, 2009 | 05:24 PM
ludecz's Avatar
Default OBD1 JDM P72 Auto to manual
Anybody knows if I can convert JDM P72 rectangular auto ecu to manual?
I know with USDM ecu's jump/cut RP17,18. But I did not find such resistor in this one, the board is 1900. I also heard about Jdm ecu's changing resistance from 2,4 to 1,4 ohms on RP18, but like I said no RP18 on this one.
Please help!
Old Sep 28, 2009 | 06:58 PM
HRTuning's Avatar
Default Re: OBD1 JDM P72 Auto to manual
Firstly, there is an RP18 on JDM ECUs so look a little harder. Secondly, it's not necessary to touch RP18. People change RP18 only to make it match what a stock manual would come as (A jumper instead of a resistor). RP17 needs to be removed, that's all.
Old Sep 29, 2009 | 10:10 AM
Relic1's Avatar
are the numbers on the ECU 37820-P72-9?? if so you can't convert or chip it.
sort of an oddball ECU.
If it's a J or some other number then go for it...
If I remember right, on JDM ECUs RP18 is on the back of the board, with the connector facing up, mid way up the right side with a cluster of other resistors.
A 1k resistor works fine also.
depending on where you are I can help you out if you'd like.
Old Sep 29, 2009 | 12:30 PM
ludecz's Avatar
Of course that's the exact numbers! What a lucky me. I thought the price was too good to be true, $70 shipped (I thought it's like USDM) :-(
Thanks guys!!
Old Sep 29, 2009 | 01:18 PM
HRTuning's Avatar
Ahh, I assumed you had the regular P72.
Old Sep 29, 2009 | 03:38 PM
Relic1's Avatar
$70 is a high price for it...
if you're interested in getting rid of it, let me know.
ryan_1014
Engine Management and Tuning
Nov 22, 2011 08:55 AM
stiffinEK
Apr 28, 2011 10:49 PM
Leviata-N
10
Oct 5, 2007 11:48 PM
streetracerof06
Feb 22, 2006 05:58 AM
B18Flip
Feb 1, 2004 04:55 PM
