98 accord problem
Old Sep 28, 2009 | 03:45 PM
cuba11's Avatar
Default 98 accord problem
I got a huge problem nd i cant seem to figure it out... iight everyone knos tht wen u have ur key into the on position all ur lights on the dash turn on... well sometimes my check engine light doesnt turn on nd my car wont start... also if im driving sometimes the car juss cuts off nd its because the check engine light poped off... its really wierd but if anyone can help please let me kno
Old Sep 28, 2009 | 04:13 PM
cuba11's Avatar
Default Re: 98 accord problem
bump
Old Sep 29, 2009 | 02:29 PM
alkoholikwun's Avatar
having any starting issues that may be related to the main relay or ignition switch? what code are you throwing?
Old Sep 29, 2009 | 04:44 PM
donaldadams's Avatar
does ur check engine light ever come on?..... the motor cutting off might b the alternator or fuel pump or something
Old Sep 29, 2009 | 04:51 PM
cuba11's Avatar
no codes throwing... nd it does come on but wen it goes out car cuts off or doesnt start
Old Sep 30, 2009 | 07:53 PM
HonBeer's Avatar
Spelling class?
Old Sep 30, 2009 | 08:04 PM
cuba11's Avatar
didnt know i was writing a paper
Old Oct 1, 2009 | 07:11 AM
sxm5369's Avatar
I have the same car and had the same issue. The problem end up being the main relay, it is under the dash next to the steering column. Apparently the solder joints in the relay are very poor and they start to crack. You can either replace it, or if you know how to solder you can do what I did and remove the old solder and resolder them properly.
Old Oct 1, 2009 | 08:26 AM
cuba11's Avatar
thnx a lot bro ima look into tht
Old Oct 1, 2009 | 02:20 PM
sxm5369's Avatar
here is a pic of where it is located under the dash
Old Oct 2, 2009 | 02:50 PM
cuba11's Avatar
i resoldered the points nd took it out for a good 15 min spin.... nd it looks like it worked hopefully it did.... thnx a lot for ur help bro
F20B6THGEN
Jul 24, 2012 09:20 AM
Doat98
Apr 9, 2012 01:37 PM
Leighza
May 29, 2007 08:20 AM
1990AccordEX
Jan 22, 2006 09:09 PM
irev210
Jun 11, 2003 07:00 PM
