NEED COMPRESSION HELP PLEASED
Old Sep 28, 2009 | 03:09 PM
C-LO's Avatar
Default NEED COMPRESSION HELP PLEASED
I DID A COMPRESSION TEST ON MY B20-VTEC AND I GOT THESE NUMBER 1-230...2-240...3-230...4-260 IS A 13-1 BUILD ON A B16 HEAD...
Old Sep 28, 2009 | 03:19 PM
lohatch's Avatar
Default Re: NEED COMPRESSION HELP PLEASED
well its either losing it past the rings or the valvejob isnt sealing on all the cylinders.
do a leakdown on it to see where it is going.
was the head rebuilt when you built the engine? did you take out the fuel pump fuse when you did the comp test? did you have the TB open?
Old Sep 28, 2009 | 03:46 PM
C-LO's Avatar
NO I HAD THE HEAD ON ANOTHER BLOCK IT WAS FINE..NO COMPUTER OUT AND DIZZY..YES TB OPEN..IS IT A NORMAL COMPRESSION OR IS IT TOO LOW...
Old Sep 29, 2009 | 06:58 PM
C-LO's Avatar
no one have an idea.....
Old Sep 29, 2009 | 07:00 PM
alterdcreations's Avatar
did you run the motor at all yet
Old Sep 29, 2009 | 07:01 PM
mar778c's Avatar
Community Builder
Community Influencer
You have a problem because the numbers should be very close to each other. Did you check valve lash?
Old Sep 29, 2009 | 07:27 PM
C-LO's Avatar
yes
Old Sep 29, 2009 | 07:31 PM
C-LO's Avatar
i check the valves they fine..i did another compression test and i got 1-230...2-80... 3-280...4-240
Old Sep 29, 2009 | 08:07 PM
DDTECH's Avatar
1) is the car operating temp when ur doing this.
2) are u cranking the car over 12 times while your foot is holding the gas pedel down.
3) if the valvelash is indeed correctly.. and you spin the car over.. and get 280.. i'd shoot for 260-280 to be decent.. ur enabled 5% variable between the numbers.
Old Sep 29, 2009 | 08:08 PM
DDTECH's Avatar
are those your pistons in ur sig? if so, with a gsr head on my b20vtec, cold i was almost getting the numbers ur getting..
Old Sep 29, 2009 | 08:09 PM
DDTECH's Avatar
you bent a valve then your first test was fine to me
your having 80 on cyl2..
you bent a valve. Jumped timing?
Old Sep 30, 2009 | 05:43 AM
C-LO's Avatar
Yeak but I have b16head
Old Sep 30, 2009 | 05:46 AM
C-LO's Avatar
I'm sorry is 280 not 80 .......
Old Sep 30, 2009 | 05:55 AM
mar778c's Avatar
Community Builder
The engine was at full operating temperature?
Old Sep 30, 2009 | 06:14 AM
josh's ep3's Avatar
Function > Form
Our last B20V was around 300 for all 4 cylinders, 12.9:1 CR.
Old Sep 30, 2009 | 06:25 AM
C-LO's Avatar
Ok thanks so they should be around that
Old Sep 30, 2009 | 09:53 AM
night's Avatar
depending on cams
94_civic_tuner
Oct 10, 2007 02:00 PM
zoom545
Nov 22, 2005 09:04 AM
Unlimitationz
Feb 22, 2005 03:47 PM
Desperado
May 12, 2003 01:35 PM
eg crunkmonster
Mar 31, 2003 08:29 AM
