A/C and Radio stop working
I have a 1992 Acura Integra GS 2dr. When I got the car, everything worked and it ran fine, but recently, the a/c quit working and soon after that, the radio as well.
I have checked all the fuses in the car and under the hood; all are fine. I have also checked the ECU and it is not throwing any codes nor a check engine light.
I have no idea what the problem is, but I'm thinking an electrical problems under the dash?
Thanks to anyone that helps.
Its probably your Alternator going out. Its not giving back enough juice I guess. Same thing happend to me, the A/C and radio just shut off randomly and on again after I moved around the radio. But I also had sudden overheating also. Once it got enough battery power everything started working normally. Or perhaps check even a wire cross in the stereo harness. Check around there before anything. Make sure no wires are sticking out or touching metal.
I've checked to make sure nothing was crossing. I left my headlights on the other day and my car died. My dad had to come jump start me and after he did that, my a/c and radio started working but only for a short while.
Yeah I'm guessing low battery level or alternator not charging it enough.
Take a battery tester, start your car and turn on your headlights. If battery level drops fast then alternator is not charging enough.
almostjdmeg
Apr 8, 2008 07:05 PM
