Lowering the front to match the rear
Old Sep 28, 2009 | 02:34 PM
w211 ryda's Avatar
Default Lowering the front to match the rear
Okay, I did some searching but couldn’t really find anything so hope you guys could help. I’ve got some Eibach Sportline on my DB7 and using OEM shocks/struts for now. I really like the front to be lower to match the rear. What are my options without having to change my springs, cutting them, or going to a coilover setup? I like how the Sportline rides, just wish the front springs are lower. This is for my dd. I’ve seen this thing called “top hats for Integras” on ebay. Will this work for what I need?
Old Sep 28, 2009 | 04:47 PM
TunerN00b's Avatar
Default Re: Lowering the front to match the rear
Top hats won't change ride height at all.
Eibach springs are supposed to lower the car evenly. Do you have a massive sub box or anything else heavy in the trunk? Or is it just that the larger front fender openings make the car look higher in the front?
Possible solutions:
1) Koni Sport shocks have different circlip locations, and can lift the rear up some by moving the circlip, but you probably don't want to buy shocks.
2) Rubber coil spring spacer in the rear to raise height.
3) Lower the front slightly through the "shock fork trick".
If it were my car, I'd just go get it aligned and not worry about it. 3 is the cheapeast solution, followed by 2.
Old Sep 28, 2009 | 08:11 PM
racebum's Avatar
if you do the fork trick make sure you get both sides even
Old Sep 30, 2009 | 11:58 AM
TunerN00b's Avatar
True.
This should be easy if the shock is pushed down such that the fork is flush with the ring that the removed brake bracket used to sit up against.
The coil spring spacer is probably the easiest to get an equal height change on both sides. They're also rather cheap.
Old Sep 30, 2009 | 03:47 PM
omnirage's Avatar
That's probably it.
Old Oct 1, 2009 | 12:37 PM
w211 ryda's Avatar
Thanks for the responses. I think I'll go for shocks. Other than Koni Yellows, are there any other shocks out there that have adjustable perchs? I see some Bilstein HDs one on sale on the classifieds and the seller claims it has adjustable perchs. I Google'd and I don't see anything in their description regarding adjustable perches.
Old Oct 1, 2009 | 01:02 PM
racebum's Avatar
you don't really know what the shock fork trick is do you.......
Old Oct 1, 2009 | 02:42 PM
w211 ryda's Avatar
I do...just don't feel comfortable cutting the brackets for the brake lines. I'll put my car on stands and check it out. Thanks.
Old Oct 1, 2009 | 02:49 PM
TunerN00b's Avatar
No need to cut.
Remove the shock and use a hammer to bang off the bracket. Reinstall shock, lower in the fork, and use a couple of zip ties to keep the brake line in place.
I used 2 zip ties per shock, 1 wrapped around the shock body, and the 2nd looped around the 1st and the brake line. Allows the tie on the shock to be tight (keep in place), yet the one on the brake line to be loose and allow some movement.
Old Oct 1, 2009 | 03:39 PM
w211 ryda's Avatar
No need to cut.
Thnx for the walk-thru Tuner! Saw other posts of people cutting their brackets so that didn't fly with me. Will definitely do the fork trick...sounds easy and cheap!
Old Oct 1, 2009 | 06:04 PM
racebum's Avatar
uh huh, you can also sell your brackets for $20 or so to people who have koni's that would like them.
sjteg
Nov 3, 2008 11:07 PM
IROCKCIVICS
Honda Civic (2001 - 2005)
Jun 11, 2007 12:37 PM
Robstunner4
Suspension & Brakes
Oct 8, 2006 09:22 AM
ludetunerz
Apr 10, 2006 04:48 PM
sp00led
May 24, 2004 07:04 PM
