Car Had No Oil - 98 GSR
Old Sep 28, 2009 | 12:03 PM
Nino_eg6's Avatar
Default Car Had No Oil - 98 GSR
I went to turn on my car on sunday night, but when I did the motor stuttered when it first turned on so I quickly turned it back off. I went to check my oil dipstick and I barely had any oil on the very end of the dipstick. I had checked my oil the day before and it was at the normal level. Im not sure what could have caused this, but if anyone might have any input; please help me out. Thanks.
If any help, Im using Mobil 1 5w-30
Old Sep 28, 2009 | 05:41 PM
Nino_eg6's Avatar
Default Re: Car Had No Oil - 98 GSR
any help?
Old Sep 28, 2009 | 05:46 PM
soon2bdropped's Avatar
topped off and see how low it is man.. either leak or oil consumption. any smoke from the exhaust when you rev it up?
Old Sep 28, 2009 | 06:59 PM
Nino_eg6's Avatar
thats the wierd thing, whenever I rev it up, there's no smoke and I can't see any visible leaks.
Old Sep 28, 2009 | 07:37 PM
racebum's Avatar
the plug or filter?
Old Sep 28, 2009 | 08:26 PM
dc2teg99's Avatar
where u hitting vtec that day hard? sometimes that will consume a lil oil... also it may be burning it if ur not driving it hard... check for smoke at idle..
Old Sep 28, 2009 | 08:28 PM
dc2teg99's Avatar
top off the oil and go for a drive then check it again..... my gsr was burning oil with lilttle to no smoke visible this is the only way i tracked it down...
Old Sep 29, 2009 | 08:20 AM
teamjdm239's Avatar
any leaks under the hood? vtec solenoid ? head gasket? check all of that as well as the filter , pan and drain plug. lmk.
Old Sep 29, 2009 | 12:02 PM
Nino_eg6's Avatar
Thanks idrivesideways, Dc2Teg99, and teamjdm239. Im going to check all these things out and get back to you asap.
Old Sep 29, 2009 | 07:13 PM
vladd's Avatar
mobil 1 is really thin and will leak and burn faster than most other oils. try using conventional oil such as castrol gtx. there's even a "high mileage" version of the gtx that's supposed to be a little thicker to prevent leaking and burning, i used it on my gsr with good results .
Old Sep 30, 2009 | 02:13 PM
Nino_eg6's Avatar
hmm ok thanks. Didnt think it would be a problem with that due to it only having 80k miles but thanks for the advice. the only reason i continued using mobil1 was because that was what the previous owner was using.
Old Sep 30, 2009 | 02:20 PM
Dogginator's Avatar
Daisy... Daisy...
Vandalism?
Old Sep 30, 2009 | 02:30 PM
Nino_eg6's Avatar
Originally Posted by Dogginator
Vandalism?
that was my first thought, but do you think they would waste their time and actually catch the oil so that I wouldn't notice? Idk :shrugs:
Old Sep 30, 2009 | 02:34 PM
Dogginator's Avatar
Daisy... Daisy...
Your talking about a quart of oil. It had to go somewhere.
Old Sep 30, 2009 | 03:23 PM
dc2teg99's Avatar
Vandalism?
seriously doubt it....
Old Sep 30, 2009 | 04:56 PM
racebum's Avatar
mobil is fine, oil has a specific film at X temp. 5-30 mobil 1 isn't going to burn faster than 5-30 dino oil. what syn does do is resist heat break down to a greater degree and flow easier cold
Old Sep 30, 2009 | 05:00 PM
mrdeadman's Avatar
They let me pick
If you check the oil when the car is cold and when the car is hot it will be in different areas... So the question is when you first checked it was it cold and when you checked it again if was warm?
19integra94
Dec 26, 2008 01:51 PM
Terrance
20
Jan 6, 2006 10:42 PM
joshalee
Aug 26, 2004 12:04 AM
Skunk_it
Oct 15, 2002 09:29 PM
