Classic Hondas All Pre-1988 Hondas.
B15A2 to direct injection?
Old Sep 28, 2009 | 09:19 AM
Simy22's Avatar
New User
Icon2 B15A2 to direct injection?
I have a 1987 Honda Civic 4 door, and I think (As most hondas... actually) That this car is just cute as a button
Shes a little out of sorts but I've been slowly getting her back up to spec.. I'm thinking of going out of my way and tweaking her as I see fit but first things first can I get a mega squirt system going... There too many tubes etc for me and I'ld rather have a DIY fuel injection kit anways, but I'ld strongly prefer direct fuel injection.
Is there a head that will fit and work well with this bullet proof motor for direct fuel injection?
And for whats its worth I know this isnt cost effective by any means however I've always wanted to do it and now I have some sort of an excuse... a weak one but an excuse none the less...
I'ld probibly have the engine done within a year assuming my new job is as good as it seems
If for whatever reason I cant get a head to work for direct injection I'll start looking for another motor, preferably one with a serpentine belt.. thanks for any constructive input.
Old Sep 28, 2009 | 12:59 PM
TunerN00b's Avatar
Default Re: B15A2 to direct injection?
Don't direct injection systems typically run absurd fuel pressure levels compared to a typical multi-port injection system, and require special injectors?
Why bother with direct injection? Doesn't MegaSquirt use a batch injection setup (all, or at least several, injectors fire together)?
Old Sep 28, 2009 | 01:25 PM
Simy22's Avatar
New User
Oh foey you seem to be correct about that
Direct injection is a smidgen more efficent from what ive read... Was hoping to get high MPG's and reliability out of everything when I'm done
I guess I'll just have to drop the idea of direct injection for now...
But yes, it does require alot of pressure, and as such high pressure and high tempature injectors...
I guess your right Tuner, I'll have to use a throttle body...
Old Oct 3, 2009 | 05:23 AM
BiGZ's Avatar
It'z D15a2 btw... (aka ew1)
Old Oct 3, 2009 | 07:42 AM
Simy22's Avatar
New User
Your correct, I dont know why I thought it was a B engine... it infact says right behinid the passenger headlight ithas a stamp that says D15A2 in fairly large font, and some other numbers (in a more normal font) which I assume is some sort of serial number....
Old Oct 19, 2012 | 04:54 AM
Sleepythecivic's Avatar
ive got a 4 door with a D15A2 also. kinda hard to find parts for :/ i cant even find a IAT for it lol tried finding different heads for it. but cant find a fit. i think im just going to do a swap!
Old Dec 11, 2012 | 01:08 PM
seanstoney420's Avatar
I have a 91 Civic Special Edition 4 door sedan with a D15A2 engine with a 16 valve fuel injected head on it.Everything I read says this engine comes with a carb not fuel injection.Has anyone ever heard of this engine/head combo or has it been modified for this head?
91 b20 integra
Classic Hondas
Jul 29, 2014 08:00 AM
Skunk2EKhatch
Mar 22, 2013 10:15 PM
vtec92accord
Mar 7, 2007 05:04 AM
redvic
Jul 7, 2004 07:44 PM
itr501
Oct 13, 2001 10:14 AM
