white smoke out my oil cap
Old Sep 28, 2009 | 03:59 AM
j_lorenzo's Avatar
Default white smoke out my oil cap
I got the same issue with a b16 60/150/60/150 new piston rings. I don't know what can be the problem, I took the head to the shop and they check it and said it was ok. I also have white smoke coming out of my oil cap any suggestion????? please help driving me crazy.
Old Oct 9, 2009 | 01:01 AM
looseOFFboost's Avatar
Default Re: white smoke out my oil cap
Your rings are bad or installed wrong whichever you choose but but there bad.
Old Oct 9, 2009 | 07:58 AM
komat's Avatar
could be ringlands too, if he only pulled the head off
Old Oct 9, 2009 | 06:32 PM
true but he said he replaced the rings. None the less he has to remove the pistons and buy a fealer guage and a manual and start over. But its definately ring related.
Old Oct 10, 2009 | 07:15 PM
projectTeG's Avatar
what color is the oil? i say blown headgasket or cracked head is a large possibility
Old Oct 10, 2009 | 07:42 PM
[QUOTE=projectTeG;40250849]what color is the oil? i say blown headgasket or cracked head is a large possibility[
I dont mean to keep speaking for this guy but I would like to know whats going on with his engine too just in case i myself run in to the situation. And its clear nobody is reading what he says. The head has been to the machine shop. Head gasket could be the issue but that would not put smoke at the oil cap at all. Lets be be technical.
Old Oct 10, 2009 | 08:29 PM
topdog's Avatar
i had the same problem with my b20/vtec from a hard HPDE weekend. removed the head and found my block was cracked in all 4 cylinder giving alot of blow by. anyways if smoke is from the oil cap will be blow by or u have to much condensation in it.
Old Oct 10, 2009 | 08:52 PM
PyroProblem's Avatar
After a compression test is done, a cylinder leakage test should be done...
When you replaced the rings, did you measure the bores?
Old Oct 11, 2009 | 08:33 AM
projectTeG's Avatar
[QUOTE=looseOFFboost;40251050]
yes a blow head gasket would put smoke out of the headgasket. on some headgasket problems you can actually hear the compression popping out of the oil cap. it it can bleed comression into the coolant system, it can bleed into the oiing system
Old May 11, 2015 | 08:22 AM
hondaman13's Avatar
I say do a compression test first!!! then do the resurface and check of the head then slap on a headgasket and you should be good to go.
codyweiss97
Mar 8, 2014 11:04 AM
z4nd
Honda Civic (2001 - 2005)
11
Aug 8, 2010 02:45 PM
Joeski99Si
Aug 2, 2009 11:25 AM
TORQUE MONSTER
Apr 23, 2003 08:28 PM
H23 Power
Aug 9, 2002 07:33 PM
