PRESS IN Cam Seal Plug?
Old Sep 27, 2009 | 09:15 PM
phateless's Avatar
Default PRESS IN Cam Seal Plug?
Has anyone got a load of the newer cam seal plugs? Honda recommends this as the preferred part to use, but I just don't know if I like the looks of it. Will post pics later, but for those who know what I'm talking about, what are your thoughts??
Here is a pic of the newer type of cam plug seal that I'm not sure I trust.
Old Sep 27, 2009 | 09:51 PM
95dc2teg's Avatar
Default Re: PRESS IN Cam Seal Plug - wtf?
why didnt u just get a blox aftermarket plug?
Old Sep 28, 2009 | 05:47 AM
follie gatts's Avatar
i doubt that is the updated part. i just replaced my leaky seal and that's what i took out.
does yours say P30 on the outside of the plug? see pic...
i think the part number is 12513-P30-000
i put in the golden eagle.
Old Sep 28, 2009 | 06:30 AM
phateless's Avatar
I think the new one says P72. Your black seal on the left is the older style, the one I have in there now. I bought one of each because I wasn't sure which one I'd use.
Old Sep 28, 2009 | 06:53 AM
night's Avatar
those push in type are what we get now in the gasket kits.
not seen a problem with them yet.
just make sure to oil up the o ring before putting it in.
Old Sep 28, 2009 | 06:57 AM
SPOOLINmatt's Avatar
works perfect for me...two different engines.
Old Sep 28, 2009 | 07:25 AM
interesting. i have no idea if my "push in" seal was orig in my 2000 LS, but it leaked badly and i just changed it out last week. i like the idea of the plug having the lip on the inside, too, but i also see the advantage of being able to pop the seal out with a screw driver. mine was really loose, though, and required very little effort to remove. i think i paid $30 for the golden eagle plug. it has three o-rings and is pretty in blue.
Old Sep 28, 2009 | 08:30 AM
erikiksaz1's Avatar
Default Re: PRESS IN Cam Seal Plug?
Is it recommended to place hondabond around the edge of the seal?
Old Sep 28, 2009 | 08:53 AM
no, just lube the o-rings with motor oil. use hondabond where the cam holder meets the head...or where the thing that holds the seal in place meets the top of your motor.
Old Sep 28, 2009 | 10:38 AM
909Dc2Racer's Avatar
i have the press in plug and it leaks
Old Sep 28, 2009 | 02:39 PM
phateless's Avatar
Hmm... lots of food for thought here. At first glance, the new press-in design looks way less secure than the old style, although I like the O-ring itself.
I currently have the old style in and it seems to leak a bit. Not bad, just dampness.
Old Sep 28, 2009 | 06:06 PM
VPUPPY's Avatar
I recently purchased an all original 2000 GSR and it had the new style in it. Honda must have started using these on later model engines.
Old Sep 28, 2009 | 07:27 PM
phateless's Avatar
I can see the advantage in that you don't have to break the seal on the valve cover gasket to change a simple cam seal plug, but I'm wondering if it actually seals better or just as well, or what? My buddy astutely pointed out that Honda is rarely wrong in their TSBs so I should probably just trust their judgment.
Like I said, just looking at it I'm skeptical.
Old Sep 28, 2009 | 08:08 PM
Spawne32's Avatar
nothing beats the dual or triple o-ring replacements
Old Dec 1, 2009 | 01:20 PM
phateless's Avatar
Still haven't got around to doing my valve adjustment and valve cover gasket, although the semester ends soon, so I'll have time then.
Any other thoughts? I still can't decide which plug to use.
Old Dec 1, 2009 | 01:31 PM
TOO MUCH TORQUE's Avatar
i have one on for 10k miles, so far its good
Old Dec 1, 2009 | 01:32 PM
just use the new one, it works flawlessly. lol its not that complicated of a decision.
Old Dec 1, 2009 | 02:06 PM
ILS_09's Avatar
I just install the same exact one you had and it worked flawlessly. No more leaks despite the fact I didn't put honda bond on mines. Just use that one. It's cheap and it works. No need to get a fancy aftermarket one.
Old Mar 30, 2010 | 11:23 AM
phateless's Avatar
I used the one with the lip on the inside. That press-in business doesn't agree with me.
Old Mar 30, 2010 | 11:58 AM
josh-roy's Avatar
I got the BLOX one, i find they seal alot better than the OEM ones.
Old Mar 30, 2010 | 12:15 PM
mouab18c1's Avatar
This is how mine looked like last winter when i purchased it from Acura. My old one did not have a rubber seal with it.
Old Mar 30, 2010 | 12:30 PM
you're going pro with this reviving old threads strategy. this one was easy since i had posted in it. i just threw another one of these press-in seals away this week. it came in the 96 i bought a few months ago.
Old Mar 30, 2010 | 12:43 PM
dammit, the press in seals work perfect, end of thread.
Old Mar 30, 2010 | 01:17 PM
why so serious? i just replaced one that leaked, so i don't agree.
Old Mar 30, 2010 | 01:51 PM
770_dc2's Avatar
replaced my oem plugged that was leaking with the gold blox one and it started to leak in about a year so order me the newer version one from blox agian since i like the gold ones from them hopefully this one will last a little longer
