windows on an 97 accord dx
Old Sep 27, 2009 | 07:31 PM
poland accord's Avatar
Default windows on an 97 accord dx
well I took my door panel off. In order to spray some, lubricant on the metal bar, or whatever the glass slides up and down. I did this thinking it would help cranking my window since it cranks hard. Any help out thier to slove this?
Old Sep 27, 2009 | 07:33 PM
Default Re: windows on an 97 accord dx
basically the window goes up an down when i crank very rough. Want to fix it.
Old Sep 27, 2009 | 07:40 PM
nus_dogg's Avatar
Thats usually what I hear other ppl do as well; just lube up the rails and it should be good for awhile.
Old Sep 27, 2009 | 08:05 PM
cd5_801's Avatar
isnt it like a grease?
Old Sep 27, 2009 | 08:10 PM
TheMuffinMan's Avatar
He knows where you live!
Yes, I believe what you want is lithium grease, if you do a search you'll find it, there's two lubricants and I can't remember the second, might be a silicone based one. Use that for the rails.
The other thing you'll want to do is use Shinentzu grease (go to Honda and ask them for it they'll know what you're talking about haha) and use that to go all over and inside the rubber seals of the window, those have built up gunk in them that slow them down.
*edit* It's Shin-Etsu Grease
Honda Part # 08798-9013
I think I paid like $7 for the tube the size of a toothpaste tube. Use that for the rubber, I think it's the lithium grease you want for the rails, but do a search. I know the Shin-Etsu is for the rubber (I use it on my S's convertible top seals)
Old Sep 27, 2009 | 08:16 PM
is'nt that the black kinda grease.
Old Sep 27, 2009 | 08:19 PM
Shin-Etsu is a white grease, you apply it with like a rag/towel and rub it in til it almost disappears, helps rejuvenate and clean the rubber.
Old Sep 27, 2009 | 09:42 PM
Genesis Accord's Avatar
I agree
I used Radio Shack Lube Gel (with teflon) on my window tracks and it seemed to work good. I also used Armor all as a temporary fix and it worked great.
I would say use the stuff Honda sells as a permanent fix.
BBallz24
Jun 10, 2008 10:28 AM
bjrta
Aug 7, 2006 07:20 AM
Luis452
Oct 31, 2005 08:07 AM
hondaowner
Dec 19, 2004 02:33 PM
Gill
Aug 13, 2002 09:46 PM
