D15B Setup Rods Question
Old Sep 27, 2009 | 05:35 AM
vipersal's Avatar
Default D15B Setup Rods Question
Hi all,
I have a crx JDM D15B with some parts like 560cc Injectors ,0.50 A/R ebay turbo, P07 pistons, FMIC, stock head tunned for me on crome with LM-1 Wideband.
My best 1/4 time is 13.352@14 psi full interior, i am very happy. lol
My trouble is the that i bought a kit of Magnitude H-Beam for D16, i know that they are the same rods for my engine but i am looking that they have 77mm on the bottom part and my pistons sleeves are 75mm.
I cant put the rod in.
Are they for B18A,B or what is wrong ?
Thanks for your help.
Old Sep 27, 2009 | 02:31 PM
trickeng's Avatar
Default Re: D15B Setup Rods Question
you have to grind clearance into the block so the forged rods don't hit the block.
Old Sep 27, 2009 | 09:09 PM
vipersal's Avatar
Thanks, I know that but the trouble is on the width part 77mm vrs the block bore 75mm
Old Sep 28, 2009 | 02:50 AM
trickeng's Avatar
??? the big end of the rod rides on the crank and doesn't go up into the cylinder, so thats not an issue.
Old Sep 28, 2009 | 04:44 AM
vipersal's Avatar
I am not talking about that movement.
my trouble is how to put the rod in the block if dont go down trough the cylinder.
Old Sep 28, 2009 | 05:20 AM
trickeng's Avatar
my bad. sorry.
Well, D16's, D15z and B18a/b all have the same rod length of 5.393" but the big ends (48mm) tells you its a B18a/b rod.
Old Sep 28, 2009 | 05:31 AM
vipersal's Avatar
my bad. sorry.
I think that, but the rods have 19mm wrist ping, not 21mm as LS Rods.
Old Sep 28, 2009 | 11:12 PM
wilham320's Avatar
the old tt rods were the same way.
you only have 3 options, take your pick.
1. sell them and buy eagle/scat rods that work.. (what i would do)
2. have a machine shop shave them to fit (what people did w/ old tt rods)
3. send the block off to get 77mm sleeve (expensive)
Old Sep 29, 2009 | 05:31 AM
vipersal's Avatar
I will go in the first option.
Thanks.
Old Jan 11, 2010 | 09:59 PM
rmz822's Avatar
they get installed thru the bottom (crank) side not head .. lol?
ryan_1014
Mar 30, 2009 05:50 AM
1.9crxNA
Oct 21, 2006 04:17 PM
CRX_Phantom1
Jan 30, 2006 05:34 PM
DC2R714
Apr 28, 2003 09:19 AM
