** GSR WON'T PASS 4K RPM :(
Old Sep 26, 2009 | 09:31 PM
southernSCHEME's Avatar
Icon3 ** GSR WON'T PASS 4K RPM :(
I NEED ALL THE HELP POSSIBLE PLEASE
I just picked up today a 98 gsr with i/h/e and its running a obd2a type-r ecu (p73)
however, it rides like **** and wont pass 4,000 rpm. it cuts off.
what can this be? motor sounds healthy and doesnt smoke
i was told the car ran good with another ecu but the guys a noob and doesnt know anything. i really like this teg and wanna get it running, please drop your feedback
Old Sep 26, 2009 | 09:35 PM
hickle's Avatar
Default Re: ** GSR WON'T PASS 4K RPM :(
well, get a gsr ecu.
Old Sep 26, 2009 | 09:48 PM
mcvic's Avatar
Try open header, maybe exhaust clogged up.
yeah. i found one locally im getting it as soon as the sun comes up hopefully thats the problem
Old Sep 26, 2009 | 10:15 PM
one car's Avatar
does it misfire?
Old Sep 26, 2009 | 10:20 PM
Brice.Hayden's Avatar
i ran a p73 ecu on my 99 gsr and didnt have any of these issues.
Old Sep 26, 2009 | 11:09 PM
Mister JDM's Avatar
maybe it's the dizzy
Old Sep 26, 2009 | 11:29 PM
it hits the rev limiter @ 4k.
alrite so if i plug in the p72 (stock gsr ecu) and it still does this i'll check the dizzy. sounds reasonable. i hope its an easy fix
Old Sep 27, 2009 | 07:12 AM
bump.anymore suggestions?
Old Sep 27, 2009 | 07:29 AM
Dogginator's Avatar
Daisy... Daisy...
Is the CEL illuminated? If so, pull the codes and let it tell you why it is in limp mode. Also, what is the P/N on the ITR ECU (37820-P73-???)?
Old Sep 27, 2009 | 02:52 PM
TYPERBLUESI's Avatar
get a gsr ecu
Old Sep 27, 2009 | 03:47 PM
dunkXdrift831's Avatar
could be a bad distributor or bad ecu.
Old Sep 27, 2009 | 04:11 PM
95twotoneteg's Avatar
my car did that and its cuz i had a check engine light that my vtec oil pressure sender was out i fixed it and it rev up all the way
Old Sep 27, 2009 | 05:28 PM
lafnda's Avatar
looks like a clogged cat or a vtec system problem. happens all the time if there is a oil pressure problem (lack of oil or a bad sender), feels like it hits a wall. most common in our shop is customers driving in with no oil in the motor and a vtec failure code.
Old Sep 27, 2009 | 05:57 PM
TypeRMOBBiN209's Avatar
a type r ecu wont open the butterflies on a gsr either
Old Sep 27, 2009 | 08:41 PM
one car's Avatar
your spark plug wires could be missing a spark.
Old Sep 30, 2009 | 07:45 PM
Mister JDM's Avatar
my homeboy had the same problem before and we changed the dizzy then everything was fine.Then my car had the same problem but mines couldn't go over 2500 rpm because it had a bad tps sensor.
Old Oct 2, 2009 | 02:49 PM
NoeDC2's Avatar
New User
someone probally did a half as tune on the ecu
Alfa164S
Jul 24, 2011 12:05 AM
Ej1-R
Mar 30, 2006 08:45 AM
