shift linkage prob
use a c-clamp, a socket, and a screwdriver bit. put the bit in the pin, put the socket on the other side of the pin. and clamp it, as you tighten the clamp agenst the bit it will push the pin out. and it will go inside the socket.. if you get that..lol
Just find a punch relative to the size of the hole that the pin goes in and tap it with a hammer and it should come out with like 3-4 taps. And NO your not hammering on your tranny. Give it a try.
yea, you're just banging on the part that controls whether you're able to go into gear or not. i'm not saying using an 8mm punch or an a/c compressor bolt won't work, because in most cases it will. i just prefer not to smack the hell out of the gear input selector and risk cracking a 15 year old transmission case.
loosestool
Sep 11, 2006 09:59 PM
mstewar
Mar 3, 2006 12:23 PM
jondancer
10
Apr 15, 2003 01:05 PM
