Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Driver side headlight dimmer than pass. side?
Old Sep 26, 2009 | 08:18 AM
hermtm2's Avatar
Default Driver side headlight dimmer than pass. side?
Hello.
I bought an used 06' LX a month ago. I didn't see any problem with headlihgts at that time. Yesterday my friend told me your headlights are not same brigthness when he saw them by a room mirror. We checked it at last night. It is obviously that drive's is dimmer than passenger side.
I put the new bulb on that but nothing change. The car looks like hitting something before I bought because there is a gap between bumper and headlight housing on the driver's side.
What makes this problem?
Thanks.
Old Sep 26, 2009 | 08:25 AM
2008fijibluesi's Avatar
Default Re: Driver side headlight dimmer than pass. side?
My guess is that there is a Silvania Silverstar bulb in the passenger side light, and a regular bulb in the driver side light.
My car has had a very slight gap between the bumper cover and both headlights since it was brandy new.
Old Sep 26, 2009 | 08:29 AM
hermtm2's Avatar
I already check to cross bulbs and put new ones. There is still driver's side dimmer than passenger.
Old Sep 26, 2009 | 08:30 AM
FijiBlueFG2's Avatar
Road House
Could be an angle of the one is off, making it appear brighter.
Could be a different bulb, as stated.
My car too has a gap between bumper and headlight. It's a Honda, not a Bentley. There is going to be gaps like that. You can loosen the bumper and refit it if you wish. It won't doo much, but the gap will diminish slightly. I did this with my rear bumper.
Old Sep 26, 2009 | 08:37 AM
Yep...I wasn't happy with the way my rear bumper cover met the quarter panels (not flush), so I had my bumper loose adjusting it the first day I had it lmao.
Old Sep 26, 2009 | 08:38 AM
hermtm2's Avatar
I mean not much gaps compare to Bentrly. I can put one of my finger onto the gaps. The front look of my car is slightly lower on driver's side. It hits something on the front bumper before I bought even though the carfax was clean.
But the different angle makes me sense.
Thanks.
Old Sep 26, 2009 | 08:39 AM
Thanks.
So...why did you buy the car?! Common sense should always trump carFAUX.
Old Sep 26, 2009 | 08:49 AM
hermtm2's Avatar
I didn't see the problem at that time.
Old Sep 26, 2009 | 08:55 AM
Are you sure you haven't hit something?
Old Sep 26, 2009 | 08:59 AM
hermtm2's Avatar
Since I bought it, absolutely no.
As usually a car is buying on daytime.
I checked every single componets as possible as I can but I did not see that much.
I want to know what problem is but not who or when.
Old Sep 26, 2009 | 09:11 AM
SpinKix's Avatar
New User
This is a longshot, but have you checked the ground wire?
Since it was possibly in an accident, maybe the body shop guys didn't tighten the screws grounding the wire if it's hard to get to.
Do you notice any flickering over a bump?
Old Sep 26, 2009 | 09:15 AM
hermtm2's Avatar
I haven't any noise from the bumper (I guess).
The ground would be worth to check.
Thanks.
Old Sep 26, 2009 | 10:40 AM
SpinKix's Avatar
New User
No problem.
Just make sure the ground wire eyelet is tight against clean metal.
They might have painted the area making a bad connection.
Old Sep 27, 2009 | 06:42 AM
rileyrat's Avatar
Also check the alignment of the headlights. The passenger's side will always be slightly higher than the driver's side. This is so you don't blind oncoming traffic but are still able to see as much as possible. It will always appear slightly dimmer, even when everything is 100% perfect.
Old Sep 27, 2009 | 02:30 PM
Yiffy's Avatar
I had the same problem, replaced both lightbulbs which fixed it.
Old Sep 28, 2009 | 02:01 PM
Nighthawk R18's Avatar
test the voltage at the headlight socket. check for corrosion or loose connections.
i dont think it could be the ground wire since headlights are wired in parallel and share the same ground. hell, check it anyway
Old Oct 16, 2009 | 12:13 PM
StupidPig's Avatar
How about the reflector? Will that be somehow cloudy on the driver side? may be water in before.
Veency
Lighting
Jul 14, 2016 01:46 AM
otsegolectric
Jul 22, 2008 10:47 AM
slikz714
Oct 20, 2005 02:21 AM
Accorddrver
Apr 27, 2004 09:41 AM
integra99blue
Jan 15, 2002 06:39 AM
