Starting To Concern Me Help If you Can
Old Sep 26, 2009 | 12:25 AM
AuroraHonda's Avatar
Post Starting To Concern Me Help If you Can
So when i drive my 1997 Accord EX F22B1 In cold Weather Or On cold Start... it does something unsusual. If im Accelerating in 1st-3rd Gear From 0-3500rpms it vibrates everything and It Feels like The Tires are Slipping on water or ice tho there not... so its kinda like the it Doesnt wanna go.. but there is no problems with it dieing or anything. I havent Had anything done to the DriveShaft Except in March i had the Driver side CV axle Replaced and the Front Motor Mount. I can only think that maybe my Tranny cuz it is is low on Fluid Cuz it is leaking from the JB welds Since February When i Bought it.
Old Sep 26, 2009 | 12:59 AM
littledude56's Avatar
Default Re: Starting To Concern Me Help If you Can
How low is the tranny fluid?
Old Sep 26, 2009 | 01:25 AM
Post Re: Starting To Concern Me Help If you Can
I'm not sure how low it is. Its a manual trans so there isn't a dipstick. And I'm not too risk taking to actually drain the tranny and refill it. But kinda would want to take the risk to save my tranny
Old Sep 26, 2009 | 10:34 AM
P_Adams's Avatar
You may be due to have the clutch changed out. It sounds like you've two conditions:
Chattering (that's your vibration) and
Slipping (that's the 'it don't want to go' complaint).
This may all lead back to your afore mentioned transmission leak. The errant fluid may have contaminated the clutch friction surfaces.
P
Old Sep 30, 2009 | 07:09 AM
hopecombs1978's Avatar
New User
Mine did this too. I thought the tranny was done, but I found that the catalytic converter was my whole problem. Have that checked first.
Old Sep 30, 2009 | 07:24 AM
uberEFtuner's Avatar
I doubt its the transmission. Where is the leak? If you look where the engine meets the transmission, you should see a small square hole. If its leaking there, that's the crankshaft seal leaking. Which will make you clutch get oil on it and slip. Put some cardboard under the car and see where the dripping is coming from exactly. Also how many miles are on it?
Old Sep 30, 2009 | 08:59 AM
hondamark35's Avatar
JB welds... whoa, what?
Old Sep 30, 2009 | 09:23 AM
Brad_and_the_acc's Avatar
My thoughts exactly...
00siandrew
Mar 16, 2014 09:27 PM
Kryss1909
Oct 8, 2008 09:37 AM
blackakkord
Sep 16, 2008 09:12 PM
dueceman
Nov 19, 2007 04:28 AM
salvageland
Nov 15, 2004 03:37 PM
