should i get arp rod bolts
Old Sep 25, 2009 | 07:24 PM
blackccoupe's Avatar
Default should i get arp rod bolts
k i'm building a block for boost i'm using low compression pistons and putting new bearings in i am using the stock rods do i need arp rod bolts or will the stock rod bolts work fine ? any help is appreciated redline will be the stock 7000
Old Sep 25, 2009 | 08:50 PM
da_dude's Avatar
Default Re: should i get arp rod bolts
Why are you even changing the pistons without the rods?
Old Sep 25, 2009 | 08:53 PM
i'm reusing the stock rods and got a deal on pistons this is a budget build will i benefit from arp rod bolts or will the stock ones be fine only going for 250 horse
Old Sep 25, 2009 | 08:58 PM
.Manny.'s Avatar
Touching My Member
how much will it cost you to machine the rods and put the arp bolts in? You can get eagle h-beam rods for like $300.
Is this for b-series? D-series?
Old Sep 25, 2009 | 08:59 PM
anyone know if i woudl benfit from using the arp rod bolts
Old Sep 25, 2009 | 09:05 PM
rat city rex's Avatar
No need for them. Factory rods will bent break b4 your rod bolt/studs will.
Old Sep 25, 2009 | 09:40 PM
j_kevin_ca's Avatar
just get them eagle rods.. dont be cheap, its better to be safe than sorry
Old Sep 25, 2009 | 09:42 PM
killerB16A's Avatar
when you put arp rod bolts in you will need to rehone the rods. by the time you pay to press the pins in and buy the rod bolts and rehone the rods......you could have just got eagle rods. i found this out from a friends build...lol
Old Sep 26, 2009 | 08:04 AM
kt hanks guys i'm gonna see what i can do thanks for the help
Old Sep 26, 2009 | 12:52 PM
Tjabo's Avatar
I know this is accepted as correct information, but I and a bunch of others have swapped in ARP rod bolts without re-sizing the big end, and it works great.
Old Sep 26, 2009 | 01:24 PM
92civiceg9gsr's Avatar
ARP rod bolts are needed for more rpm, not to make the rod hold more power.
bigwheel1983
Apr 11, 2012 12:39 AM
Jordb22
Jan 31, 2012 08:37 PM
neyrod
Feb 16, 2005 11:05 AM
CrX-To-Tha-Max-v2.0
Oct 28, 2004 03:59 PM
