1990 Manual Transmission Problem Need help Fast!!!
Old Sep 25, 2009 | 06:45 PM
Tabers's Avatar
New User
Default 1990 Manual Transmission Problem Need help Fast!!!
My 1990 Accord dx 5 speed has a trany problem... it started out as every once in a while and now its every time i start the car.... Once started i push the clutch in as usual but i am enable to put it in any gear! It is like i am not even pushing the clutch in.... When this happens i have to ether force it in gear or turn the car off and start it in gear to get it rolling and power shift it to every gear! i have checked the linkage and when the clutch is pushed in the slave cylinder IS moving the arm.... i have bled fluid and replaced it with new ( no bubbles) ... ALSO when the car is still and i push the clutch to the floor a sound comes from the trans like a power steering pump low on fluid??? PLEASE HELP!!!!!!
Old Sep 25, 2009 | 07:45 PM
P_Adams's Avatar
Default Re: 1990 Manual Transmission Problem Need help Fast!!!
You've more than likely got a leak in the clutch release mechanism, you've run low on fluid because of this and have now reached a point where you've lost enough travel that the clutch won't release.
I would look at the Clutch Master Cylinder and then the Clutch Slave Cylinder. They both develop leaks if the fluid's never changed, and it sounds like you're the latest victim.
P
Old Sep 25, 2009 | 09:24 PM
Tabers's Avatar
New User
So if i replace both of those is there a good chance that it will fix the problem????
Old Sep 26, 2009 | 01:28 AM
Zappythebum's Avatar
try inspecting them and let us know if there is a leak.
Old Sep 26, 2009 | 10:01 AM
nus_dogg's Avatar
Check your clutch Master & Slave cyl to see if they're shot; fluid leak.
Old Sep 26, 2009 | 10:19 AM
P_Adams's Avatar
It's either one or the other, yes
If you take the time to inspect both, you'll find which one is the culprit.
When it comes time to look at the Clutch Master Cylinder, pay particular attention to where it mounts to the firewall; they usually leak at that point - leaving a telltail trail of fluid. Be aware that this could show up under the dash, again on the firewall.
P
Old Oct 4, 2009 | 12:40 PM
Tabers's Avatar
New User
I replaced both the master cylinder and the slave... nothing helped ... over the last couple days i have removed the trany and found that the clutch has two broken springs!!! Crazy i have never seen this before nor any of my gear headed friends.... i replaced the clutch and pressure plate last night and tonight the trany will go back in aswell and everything else... ill let ya know how it goes along with pics....
Tabers
Old Oct 4, 2009 | 12:48 PM
CeReal's Avatar
make sure none of the wires get trapped inside the tranny housing. same thing happened to me, was in a hurry to put it back together, and hooking up the wires i find i am missing one connection. FFFFFFFFFFF.
Dav94Lx
Feb 2, 2008 07:53 AM
mattmw88
Dec 9, 2006 06:00 AM
integnewb
Mar 17, 2006 12:18 PM
RainingRed24
Oct 11, 2005 01:47 PM
