Suspension & Brakes Theory, alignment, spring rates....
Replaced Brakes few months back now needs new pads!
Old Sep 25, 2009 | 12:20 PM
MachAF's Avatar
Default Replaced Brakes few months back now needs new pads!
So I replaced all four brake pads and rotors a few months ago. Now my right rear brake pad is completely gone. WTF? All the other pads look fine.
There isn't anyway to adjust the brakes that I know of.
Any ideas what the problem might be? I guess I'll be getting new pads tomorrow. Same thing is probably going to happen in a few more months...
Old Sep 25, 2009 | 03:30 PM
cdntegintx's Avatar
Default Re: Replaced Brakes few months back now needs new pads!
Is it both right rear brake pads? or just one side? If it's just one you probably have a seized/sticking caliper slider.
Old Sep 25, 2009 | 03:47 PM
MachAF's Avatar
Just the right rear side. How should I go about fixing that? Replace the entire caliper?
Now that I think about it, it kinda feels like its sticking a little bit.
Old Sep 25, 2009 | 04:34 PM
TunerN00b's Avatar
If the silder is stuck, no need to replace anything.
Remove the slider bolts, clean very well, lube the snot out of them, and reinstall.
Old Sep 25, 2009 | 04:40 PM
MachAF's Avatar
Thanks. I'll go at it tomorrow.
Old Sep 26, 2009 | 10:02 AM
MachAF's Avatar
Here is what I found.
The outside brake pad is completely worn. The inside pad is completely fine.
On the caliper there seems to be a hole in the seal. I assume this is what us causing the problem?
http://lh3.ggpht.com/_kvpb1tYBBEw/Sr...oto%285%29.jpg
Could I just get some RTV silicon and seal that hole? Or would I be better off buying a new caliper? This is my beater car so I prefer not to dump money into it.
born2lose
11
Jun 17, 2012 06:27 PM
cmyates007
18
Apr 14, 2012 10:19 PM
vidanator
Jul 21, 2005 12:07 PM
skunk2eg
Nov 3, 2004 11:58 AM
blkbeast
Jan 14, 2002 12:58 PM
