Which distributor Fits which for B-series?
Old Sep 25, 2009 | 09:46 AM
casper_hb's Avatar
Default Which distributor Fits which for B-series?
I am wondering the fitments for B-series distributor?
LS fit GSR?
B16 fit gsr?
type r fit gsr?
If it does, will it lagg power or will it be the same?
Because my gsr distributor broke and i need one. I have a LS distritbutor. Will it fit. and will there be any loss of power if i put an LS distibutor in?
Old Sep 25, 2009 | 10:19 AM
seanbev24's Avatar
Default Re: Which distributor Fits which for B-series?
All b-series vtec distributors will fit the gsr with no mods assuming it's the same obd. An LS dizzy will work but requires some modification (you have to cut a piece off).
Is your car obd1 or obd2? If the dizzy you are trying to use is a different obd, it will require some wiring modification. OBD0 distributors will not work.
There is absolutely no power difference using a non-gsr dizzy. It's like people thinking a type R vtec solenoid will make their "vtec crack harder" it really makes no difference.
Old Sep 25, 2009 | 02:24 PM
casper_hb's Avatar
thanks bro.
my gsr is obd2 the ls is obd2 too. but my chasis is obd1.
so what do i have to cut i8n the ls distributor???
Old Sep 25, 2009 | 08:59 PM
projectTeG's Avatar
the front leg, but still i did that it work, but i dont trust one bolt holding the dizzy in, i had horrible oil leaks from it. do it to get going, but change as soon as you can.
tip if you get a b16 dizzy you can swap internal parts withe the ls dizzy(all internals the same) the gsr and ITR share parts, i like the b16 because ls parts are easier to come by and also majority of all other honda dizzy internals will fit too.
Old Sep 26, 2009 | 07:37 PM
JAYDmManny1331's Avatar
is it harder to time the car !!
Old Sep 26, 2009 | 08:17 PM
projectTeG's Avatar
no same
Old Sep 28, 2009 | 09:18 AM
casper_hb's Avatar
so the hole from the ls distributor wont allign with the whole on the head then?
Old Sep 28, 2009 | 09:35 AM
projectTeG's Avatar
only one will the top one, the one near the vtec solenoid needs to be cut off.
mapa1229
Jan 22, 2011 04:58 PM
ek9jdm
Nov 29, 2006 01:06 AM
EKB18BPR3
Jan 23, 2005 01:34 PM
Shoe
Aug 25, 2001 05:32 AM
