Transmission & Drivetrain Gearboxes, Differentials, Clutches
What should be considered when replacing Input Shaft Bearing?
Old Sep 25, 2009 | 08:27 AM
95_Civic_4dr's Avatar
Default What should be considered when replacing Input Shaft Bearing?
D16z6 5-speed
I get a knocking/clicking noise from the tranny whenever I'm idling and have the clutch pedal released so after some research on here I came the conclusion that my ISB was bad. I have the replacement ISB and seal for it. I've been putting this off for a month or two and I would like to get it done this weekend while the car still runs fine and shifts smoothly before any other damage happens. It's my first time pulling the tranny out but I'm confident I can get it done even if it takes all night, I just wanted to know if there's any other bearings/gears I should look at while it's out, maybe even replace.
Old Sep 25, 2009 | 08:54 AM
morgan@synapse motorsport's Avatar
Default Re: What should be considered when replacing Input Shaft Bearing?
I would get both mainshaft bearings and check the countershaft bearings carefully. These gearboxes are getting old and more often then not you have a few bearings failing.
Old Sep 25, 2009 | 05:30 PM
Mista Bone's Avatar
D Tranny Guru
ISB and 4 seals, inspect 1-2 and 3-4 shifter forks, stake in countershaft bearing.
r.f.b
13
Nov 2, 2017 06:45 AM
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
Eklsv-t
Aug 28, 2008 10:52 AM
Patman
Jul 30, 2008 08:36 PM
zman
Aug 22, 2004 08:41 AM
