Suspension & Brakes Theory, alignment, spring rates....
Help! Skunk2 camber kit bolts!
Old Sep 25, 2009 | 08:15 AM
AxKaose's Avatar
Default Help! Skunk2 camber kit bolts!
I already tried the seach but came with no answer. But anyway, I need to replace a few of the
Allen head Bolts for my skunk 2 camber kit. I was wondering if anyone knew what the size of these bolts are?
Or a better replacement bolt to use. Mine are pretty much rounded out so they won't work.
The bolts I'm referring to are the ones by the ball joint. Oh yeah, I have a skunk2 pro series kit for my db integra.
Thanks
Old Sep 25, 2009 | 12:49 PM
eK24monster's Avatar
Default Re: Help! Skunk2 camber kit bolts!
You can contact Skunk2 to buy new ones... they work fine if you use the right size allen.
Old Sep 25, 2009 | 01:30 PM
Andy@AMR's Avatar
Your talking about the 4 allen bolts right. Cause I lost 2 from one side, and 1 from another when I took my suspension apart. I have no idea how that could have happened since I had locktite on those suckers. I just went to the local True Value hardware, and got some replacements. They were only like 65 cents a piece, and while I was at it, I added some lock washers. Just take one of them with you, I was able to get the exact same size pretty easily. I'm sorry, I wish I remembered what size they were off the top of my head.
Old Sep 25, 2009 | 01:53 PM
bokals's Avatar
I would replace those allen bolts with regular hex bolts. Make it easy on yourself!
Old Sep 28, 2009 | 08:46 AM
AxKaose's Avatar
Thanks for the help guys. I found some replacement bolts at the local Knechts shop.
They were an exact match. Thanks again! This thread can be closed.
Charlie Moua
Suspension & Brakes
May 5, 2009 06:14 PM
dohcVTECeg2
Suspension & Brakes
Dec 26, 2005 08:48 AM
Si Shane
Dec 22, 2005 11:46 AM
nerces
Jul 26, 2003 06:18 PM
toeandheel
Mar 2, 2003 08:30 PM
