i Need a AWESOME Tuner
Old Aug 28, 2002 | 08:36 AM
-iLLuZioN-B18C1's Avatar
Default i Need a AWESOME Tuner
does anyone know a good one from Atlanta Georgia???
need to tune the hell out of my GSR(the shop put in some jdm itr
pistons--i think around 11 something compression) so i need to
tune it to hell cause im getting turbo soon!!
Old Aug 28, 2002 | 08:38 AM
H-PIMP's Avatar
Default Re: i Need a AWESOME Tuner (jvithayapun)
Sounds like they installed n/a pistons in your car. 11+ CR will not work well with a Turbo set-up. Contact a reputable shop in your area and decide wether you wanna go Turbo or n/a.
Old Aug 28, 2002 | 08:41 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: i Need a AWESOME Tuner (H-PIMP)
Take it back to that shop and have those pistons taken out. Replace them with something with a lower compression THEN think about turbo and tuning.
Old Aug 28, 2002 | 09:00 AM
uNF$@#!'s Avatar
Default Re: i Need a AWESOME Tuner (Rguy)
TURBOCHARGERS & COMPRESSION: THE MYTH!!!
There has been a long-standing myth with turbocharged Honda cars. For as long as I can remember, people have been quite concerned about having too high of a compression ratio, on their turbocharged Honda. The myth is: the lower the compression...the better. Well, this is not entirely true.
Why is a low compression motor good to turbocharge?
In essence, a low compression motor is good to turbocharge, because it is just easier to do so...and not worry about it. But is that what we really want to do as enthusiasts? Do we want to just slap a turbocharger on a car, and call it a day? Absolutely not. With turbocharging, comes the responsibility of tuning and care. If you are just going to turbocharge your car, and call it a day, then frankly, you don't deserve the luxery of boost! As well, might I add...that simply because it is easy to slap a turbocharger on a low compression motor and not worry about it, does not mean that it is right. I can guarantee you, that if you turbocharge a low compression motor, and fail to tune it correctly, you will end up on the side of the road, with blue smoke coming from your exhaust pipe.
Generally, a lower compression motor affords you more margin of error, when tuning. A slightly imperfect a:f ratio probably won't lead to the demise of your motor...unless you drive like a total jerk.
Why should I consider a higher compression motor, while making my decision of what motor will suit my needs?
Different from a low compression motor, a higher compression motor will not give you a large margin of error, when tuning. As stated before, if you expect to slap on a turbocharger, and call it a day, well then stay away from the higher compression motors all together. A higher compression motor demands slightly more TLC than a lower compression motor. But oh, the rewards are plenty.
Bottom line...a higher compression motor, pound for pound, will make more power, than a low compression motor. This works along the same lines as naturally aspirated Honda motors. You never see an NA enthusiasts spouting off about low compression do you? No, one of the keys to NA performance is high compression. So, why should it be any differnt for turbocharged applications? Of course, the routes to high compression are different (NA uses lightweight rods and pistons, that a turbocharged application would simply tear to shreds), but the end goal is the same.
Let's make an observation here. I am going to throw a scenerio for you...
Car A:
B18B (stock 9.2:1 CR)
Rev Hard Stage II
Thermal 3" exhaust
MSD 6AL
MSD Pro Cap
MSD Blaster 3 Coil
Holley 255lph in-tank fuel pump
AEM fuel rail
RC440cc injectors
A'pex S-AFC
Car B:
B18B (JE pistons, 10.5:1 CR)
Rev Hard Stage II
Thermal 3" exhaust
MSD 6AL
MSD Pro Cap
MSD Blaster 3 Coil
AEM fuel rail
RC440cc injectors
A'pex S-AFC
Now for the sake of argument, let's say that both cars are well tuned, by the same tuner, both have an identical weight, both have the same slicks, both are boosting 1.0bar, and both are being driven by the same guy...at the same time (yeah, yeah, yeah...just roll with me here)! Now, which one do you think is going to come across the finish line first? Mythological thinking says that the guy with the low compression is best suited to win...right? Wrong. The guy with the 10.5:1 compression ratio is going to smoke the guy with the low compression.
Another point I would like to bring up is the misuse of the term "high compression" when it comes to Honda motors, and turbocharging them. In all honesty...10.6:1, 11.0:1, etc...aren't even really that high. Most NA monsters utilize 12.5:1 or higher...and some even as high as 14.0:1, in cases of extreme race. If you do some snooping around, you will realize that most of the really fast Hondas, and I'm talking sub-10 second monsters, utilize high compression setups, to achieve enourmous horsepower goals. Most of these guys won't openly discuss it though, so you are likely to come across terms such as "undisclosed compression", or something along that line. As I stated before, the myth is that low compression is key...so these guys want to stay on top, and the way to do it is hide the fact that they are using high compression, turbocharged motors...to propel themselves into sub-10's.
Reliability, and compression...
This is a regular question that pops up, and is quite valid. Frankly, as soon as you modify a Honda at all...reliability becomes an issue. A lot of us can testify that the proverbial "can of worms" sprung open as soon as we made our first modification. Many times, Honda enthusiasts will spout off the reliability factor, in Import vs. Domestic wars, when in actuality, they fail to realize that we are in just as much danger as those old pushrod V8's are, as soon as we modify our Honda engines.
Now, what is the solution? I have been saying it for a long time, as have several others such as Tuan, neouser, texan, and st00pid...TUNING IS KEY! That's the bottom line.
A well tuned higher compression motor will last just as long as any low compression motor. Tuning is not a factor that can afford to be sacraficed. You will not survive with an untuned higher compression motor, just as you will not survive with an untuned low compression motor.
So, with all of that said, it basically boils down to your own personal choice. Do not fear the B16A, the B18C1, or the H22A...etc. If you have the monitary requirement to turbocharge a higher compression VTEC motor, I would say, do not hesitate to do so.
As i saw in a someones signature the other day...
You can have either Cheap, Reliable, or Fast
Cheap and Fast can't be Reliable
Fast and Reliable can't be Cheap
Cheap and Reliable can't be Fast
Tuning is not necessarily cheap when you have to do it every month on a turboed honda, but the above statement says it all.
J-i-g-g-y
Old Aug 28, 2002 | 09:20 AM
JPP's Avatar
JPP
Default Re: i Need a AWESOME Tuner (Soup ****)
Very nice Soup **** but that doesn't really answer the original question now does it??? NEXT!!!!!!
Old Aug 28, 2002 | 10:23 AM
Tweakmeister's Avatar
Default Re: i Need a AWESOME Tuner (JPP)
you need the mad scientist...give a holla to cali.
Old Aug 28, 2002 | 10:27 AM
dustin's Avatar
Default Re: i Need a AWESOME Tuner (Tweakmeister)
If you are going turbo on pump gas, you are going to definately need to "tune the hell" out of your car.
Old Aug 28, 2002 | 10:31 AM
sgT's Avatar
sgT
Default Re: i Need a AWESOME Tuner (dustin)
as long as the boost is kept down, it should be okay
Old Aug 28, 2002 | 10:35 AM
H-PIMP's Avatar
Default Re: i Need a AWESOME Tuner (sgT)
I made excellent numbers with my stock compression GSR motor @ 10 psi, injectors, pump, MSD, FMU, etc. Were also there. But on 10 psi that stock motor really screamed! Not to say that it would last a long long time the way a built block would, but it definetly spooled very quickly and ran very hard...mid 12's in a del Sol.
civic-r11
Mar 31, 2009 12:04 PM
lsvtecej95
Apr 1, 2008 06:38 AM
galioth
Jan 16, 2007 11:48 AM
scUba-stEve
Apr 2, 2005 06:23 PM
transmission11
Dec 30, 2002 10:02 PM
