ELD PROBLEMS....need help..?
Old Sep 24, 2009 | 06:13 PM
brian1991's Avatar
Post ELD PROBLEMS....need help..?
91 hatch bwith a b16 swap, keep throwing cel code 20- eld (electrical load detector) and this is what ive done as far as troubleshooting and im lost,
pulled 3 pin eld harness from fuse box in engine bay, check for voltage between black and yellow and ground, which goes to main fuse box under dash, good i think between 4-5 volts, and green and red and ground, which goes to ecm, or pcm, NO volts, checked the wire and nothing wrong with it and the pin connections good, so i replaced entire fuse box and nothing,
im lost here and dont know what to do or try and i dont want to take it to a dealer b/c they look at my car and motor and their head starts spinning with all the stuff i have on it and just the swap in general, plus i dont want to pay an arm and a leg for nothing, last time they put a switch on my ecu to just turn off my cel. a holes,
Old Sep 28, 2009 | 04:41 PM
brian1991's Avatar
Default Re: ELD PROBLEMS....need help..?
any help anyone.....im lost, lots of views but no posts, someone please give me somthing....wheres all the techs at....
Old Sep 28, 2009 | 05:21 PM
Crx Jimmy's Avatar
what ecu are you using? what jumper harness are you using?
Old Sep 28, 2009 | 10:23 PM
EF-Devotion's Avatar
are you having problems with starting, headlights or etc. or is there a check engine light and you just try to kill it.
Old Sep 29, 2009 | 06:46 AM
jlicrx's Avatar
code 20 is usually a bad or dying alternator
Old Sep 29, 2009 | 07:21 AM
Mr.Death's Avatar
Check for loose or corroded grounds.
Old Sep 29, 2009 | 02:37 PM
brian1991's Avatar
pr3 jumper and ecu
Old Sep 29, 2009 | 02:40 PM
brian1991's Avatar
no problems starting, runs perfectly fine, idles perfectly fine, checked all wires, fuse 14 under dash, replaced fuse box under hood twice, checked all grounds, cant find anything thats what i dont understand, but cel is on all the time.
Old Sep 29, 2009 | 02:42 PM
brian1991's Avatar
and headlights and everthing electrical work fine radio/cd player, i duno im lost here
Old Sep 29, 2009 | 04:46 PM
civiccrx's Avatar
Did you convert your car from DPFI to MPFI?
I did a bad mpfi swap and threw a code 20. I mispinned one pin over and that was the cause. It took me a good 40+ hours to figure that one out.
Old Sep 29, 2009 | 05:46 PM
must be like civiccrx said. check wirings. also could be alternator. Mine threw no codes but ELD was fault. My lights kept flickering and radio kept turning off and on once in a while (alternator and battery good). replace my alternator and still same thing. One night my light and indash lights kept flickering really bad and it died on me. Took it to a mechanic and he took 3 weeks to fix my car. It was my Eld and 2 burnt wires( i think he said underneath my dash- steering colum). after that my car was running and running great right now.
Old Sep 30, 2009 | 04:22 PM
brian1991's Avatar
i dunno what it is, but read the post ppl, my car runs fine, idles fine, lights dont flicker cd/radio works great not problems with anything on the car as far as electrical or mechanically, checked all wires over and over and over a went through the pin outs several times checked everything and i mean every little thing, checked fuses, changed fuse box under hood twice, nothing, also its not my alternator i ran a few test on it and its good recharging my system fine, thats why im stumped here i cant figure it out, i ready to say heck with it
Old Sep 30, 2009 | 05:01 PM
civiccrx's Avatar
I here have read your post, along with some others. I'm telling you that I had the SAME problem. Only thing was a check engine light that was pissing me off and showing code 20. I also checked my wires over and over and over and over again. I changed the fusebox under the hood a couple times too. I even took the dash out and replaced the fuseblock under the dash. ONE wire mispinned out of how many at the ecu? I am really happy now that it's gone though.
I would, bring it to someone who has the patience to check the wires at the ecu. I takes many painful hours to disect the problem. I am not exaggerating when I say 40+ hours to figure it out.
Old Oct 1, 2009 | 04:31 PM
brian1991's Avatar
ill keep plugging away at it i guess i probably have about 30 hrs. of looking and tearing apart and more looking and checkeing pin out on ecu and god knows what else so hopefully 10 more hrs. and ill have it solved, but ill keeping messing with it here and there, and ill post if i make any breakthroughs
Old Oct 1, 2009 | 06:01 PM
scottmog's Avatar
if u got a bad eld then buy a new alternator. i had a bad eld last week, bought a new one, perfect now.
Old Oct 3, 2009 | 06:30 PM
brian1991's Avatar
i dunno if its my alternator because i ran a few tests on it and its fine, its recharging my system perfectly fine, i dunno maybe its worth a shot, if i can find one cheap enough because to be honest i dont think thats the problem, im thinking a wire somewhere that i havent found yet ot somthing i just skimmed over after getting tired of looking and looking......but thanks for the input like i said ill try it if i can find one cheap enough or see if any friends have one laying around
Old Oct 11, 2009 | 01:56 AM
95jdmcivic's Avatar
im in the same boat as you, im now throwing CEL 20. Ive noticed a month ago that my headlights would not come on when i turned them on and i had to hit the under-hood fuse box for them to come on.
mugenEJ1_777
May 29, 2010 02:36 PM
mugenEJ1_777
May 29, 2010 01:33 PM
Mr.Death
Jun 10, 2007 08:44 AM
bobss
Apr 2, 2007 09:24 AM
civic95hbvtec
Jun 23, 2005 02:24 AM
