entry light/dome light
Old Sep 24, 2009 | 03:05 PM
zsudz922's Avatar
Default entry light/dome light
is there any reason my entry light would not work with the dash pulled out of my 96 prelude (including tach/cluster)? the dome light works when i flip the switch to ON, but it wont work when the light switch is on "door" with either of the door opened. when the driver door is open the ignition light turns on and it will make the ringing noise when i leave my lights on and open the door. any reason my entry light does not work with the dash out?
im in the process of installing my alarm system (python 1090) and was wondering if i splice the green(door trigger) with the black/white?(dome light) and run it to the driver and passenger door triggers(isolated with diodes), when i unlock my car will it illuminate the dome light?
any info is appreciated!
Old Sep 30, 2009 | 10:30 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: entry light/dome light
There is a short some were in the door wire. You can simple retag each door and tag it to the piller door trigger wire and everything will work again.
Old Oct 1, 2009 | 07:19 AM
zsudz922's Avatar
Originally Posted by whomster
ok found it. pin 21 of the c614 connector (instrument panel) provides path to door switch via pin 26. no dash installed no connection to door switches...
therefore no dome light. works in "on" position as ground path is provided internally.
that would be why my entry light does not work but the chime and ingnition light work.
thanks though!
Old Oct 1, 2009 | 09:39 AM
Your door chime does not have to do with anything with the door switches. There is a key sence button on the key cylinder. You have two options, The hard way by tracing the short. OR re-wire it to factory like above.
Old Oct 1, 2009 | 10:09 AM
zsudz922's Avatar
what does the key sense button have anything to do with this? in my OP i said "when the driver door is open the ignition light turns on and it will make the ringing noise when i leave my lights on and open the door." meaning when i open my door(no key in the ignition) the ignition cylinder light turns on and if i turn my parking lights on the chime will ring.
Old Oct 1, 2009 | 01:41 PM
reading owns me on that one. I have a 96 lude that we are working on now. I will go over this one to see if I can figure out your problem and trace this car circuit.
Old Oct 1, 2009 | 02:21 PM
zsudz922's Avatar
lol. cool, thanks man. pretty sure your going to come up with the answer that whomster cam up with, but who knows.
hon0405
Dec 7, 2016 01:29 PM
DCiFound
Lighting
Jul 13, 2014 07:57 PM
zsudz922
Sep 25, 2009 08:25 AM
aalb1
Mar 26, 2009 08:43 PM
rice4life
Jun 14, 2002 07:34 AM
