QUSETION?? B16A3 OBD2?
Old Sep 24, 2009 | 02:57 PM
joeitovtec69's Avatar
Default QUSETION?? B16A3 OBD2?
HI .. IVE BEEN SERCHING AND CANT FIND AN ANSWER..
IM THINKING ABOUT BUYING A 1997 CIVIC HB.. IT HAS A B16A3 OBD1 SWAP FROM A DEL SOL .. NOW THE QUESTION IS .. CAN I GET THIS TO PASS INSPECTION WITHOUT AN ENGINE LIGHT.. CAR HAS OBD1 INJECTIORS, DIST, ALT. ON A SPLICED OBD2 HARNESS ..WITH A OBD 1 JUMPER..
WHAT WOULD I HAVE TO DO???
Old Sep 24, 2009 | 06:46 PM
seanbev24's Avatar
Default Re: QUSETION?? B16A3 OBD2?
If your state's inspection consists of plugging a scan tool into the obd2 data port, then no, i don't think it would pass. I don't have personal experience with this though, never owned an obd2 car.
Old Sep 25, 2009 | 03:20 AM
YES IN NJ THEY DO.. BUT I WAS TOLD NOW IF JUST TO PASS.. I USE A OBD2 LS ECU.. THE 2 CODES ARE SECONDARY O2 SENSOR AND THE MOST IMPORTANT CRANK POSITION SENSOR?? WHICH OBD1 DONT HAVE NOW CAN I BYPASS THE CPS
Old Sep 25, 2009 | 05:15 AM
94EG8's Avatar
Seagull Management
Run and OBD2 USDM '96 - '97 Del Sol VTEC ECU (OBD2 P30) (remember that JDM OBD2 ECUs will not communicate with a scan tool. Perform the CKF fix shown here ---> http://technet.ff-squad.com/ckftrick.htm
Wire in the seconday O2 sensor. Provided your state doesn't actually check to see that the engine is older than the car it should pass just fine
flash0124
Engine Management and Tuning
Oct 19, 2012 08:32 PM
Brugalontherocks
Apr 28, 2008 08:10 PM
FrederickRighteous
Mar 17, 2008 11:27 AM
EgSalad
Jan 30, 2007 07:57 AM
S4gasm
Oct 30, 2004 12:05 PM
