91 NSX detail/orange peel correction
I did an NSX this week, such a beautiful car.
The owner had the front bumper re sprayed because of rock chips and it was left a little orange peel-y so I corrected that and finished with an exterior detail and swirl removal (not many swirls at all).
pre-soak
The orange peel issue:
Wet sanding:
Buffing:
finished with buffing and polishing:
Orange peel issue resolved:
Finished pics:
pre-soak
Wet sanding:
Buffing:
Finished pics:
I used Meguiar's unigrit 2,000 grit. 3M sand paper is also great for cars. They both have a much better consistency in their sand than other papers so you get better results.
The process was wet sanding with 2,000grit (of course)
M105 w/ medium-cut wool pad > M205 w/ yellow polishing pad > M21 sealant applied by hand.
Next time i correct orange peel i'll do a write up.
