Re: 91 NSX detail/orange peel correction
good job! u are one lucky guy...did u get to test drive it?
Great work on the orange peel!
what grit did you use? could you do a write up of it?
I used Meguiar's unigrit 2,000 grit. 3M sand paper is also great for cars. They both have a much better consistency in their sand than other papers so you get better results.
The process was wet sanding with 2,000grit (of course) M105 w/ medium-cut wool pad > M205 w/ yellow polishing pad > M21 sealant applied by hand. Next time i correct orange peel i'll do a write up. |
Awesome job. Mine looks almost exactly the same and needs some detail work done for sure.
Tell the owner of that Nsx to get some real man tires for it, 615's don't cut it in that car :P
Sick car and sick work, what kind of buffer did you use for that? |
mmmmm...acura nsSEX
