Removing auto shift linkage
Old Sep 23, 2009 | 08:10 PM
fastlane2's Avatar
Default Removing auto shift linkage
I'm removing my F22 auto for a H22. How do I remove the shift linkage on the auto trans. Looks tricky.
Old Sep 23, 2009 | 10:49 PM
02 accord's Avatar
Default Re: Removing auto shift linkage
Bend the locking tab out of the way, remove the 10mm screw, and it should slide right off.
Old Sep 24, 2009 | 06:46 AM
granny racer's Avatar
will an h23 bolt up to an auto transmission from an f22b2 ?
and run
Old Sep 24, 2009 | 03:02 PM
alkoholikwun's Avatar
F and H series motor and tranny all interchangeable
Old Sep 25, 2009 | 09:19 PM
fastlane2's Avatar
Good then will my F22B2 OB2 bolt up to a 98 F engine. Has any one done it. also I just removed my linkage on the auto, just a plate to up do on the bottom. Next is my H22A auto!
Old Sep 25, 2009 | 09:47 PM
bseriescrxsi's Avatar
actually try not to bend the tab.......remove the pin and shim a flat head in there and wiggle the clip loose....thge linkage will come off rather easy.....just make sure that if the little bearing comes out of the middle of the linkage you catch it n remember to put it back in
Old Oct 2, 2009 | 05:54 PM
ive heard that the f22 will not work with the f23 because of the different TCU solenoid.
so for AUTO, will "NOT" work, only for manual.
Old Oct 2, 2009 | 06:46 PM
fastlane2's Avatar
Thanks thats what I wanted to know. Now who wants a F22 atuo tranny with 60k on it? Used z1 fuild every 15k to 20k
ITRinEJ1
Jul 26, 2002 10:02 AM
