which guage cluster will fit?
Old Aug 28, 2002 | 06:21 AM
GroundZer0's Avatar
Default which guage cluster will fit?
The RPM on my guage cluster does not work, so i way thinkin about a new one. Could you tell me which honda models guage cluster would fit my 91 CRX HF?
Thank you.
Old Aug 28, 2002 | 06:25 AM
Hondasaurs's Avatar
Default Re: which guage cluster will fit? (GroundZer0)
Before you spend money on a new one pull your instrument cluster apart and make sure all of your connections are tight.
Old Aug 28, 2002 | 06:45 AM
USDM 4G VTEC's Avatar
get an aftermarket one
the readings are going to be more accurate and they response faster...
Old Aug 28, 2002 | 06:57 AM
GroundZer0's Avatar
Default Re: which guage cluster will fit? (JDM EF9)
ZC : i have done that like 3 times, the rpm guage dosent work, and i dont know what other ones dont work. Is there anything else i should check.
For an aftermarket one, should i get a tachometer, like RPM's or what should i get? Thanky you.
Old Aug 28, 2002 | 07:26 AM
Hondasaurs's Avatar
This is true. I use an autometer tach. It gives a much better reading than the stock tach.
Old Aug 28, 2002 | 07:35 AM
GroundZer0's Avatar
Default Re: which guage cluster will fit? (ZC_CRX)
Which brand do you reccomend?
Old Aug 28, 2002 | 07:44 AM
SuperCivic's Avatar
mONsTA tAcH yO!!!!
Old Aug 28, 2002 | 07:52 AM
GroundZer0's Avatar
Default Re: which guage cluster will fit? (SuperCivic)
Those are the ones i was actually just looking at. Do you kow any good sites i can buy em at, like good prices or what not.
Old Aug 28, 2002 | 08:04 AM
Cereal_Killer's Avatar
check autometers website. www.autometer.com or just go to the calssifeids in a few other forums. somone is usually always selling one.
Supa Troopa
62
Jul 19, 2023 10:07 AM
sstupid
Nov 19, 2014 04:20 PM
triple5soul8781
Aug 7, 2008 05:46 AM
superex87
May 24, 2007 04:44 PM
89DXDann
Jun 4, 2004 11:38 PM
