How tight to tighten lug nuts on wheels??
85 lb/ft
and yes it can warp your rotors by over torquing. You heard right
It's 80-85, you may or may not need to adapt a few ft lbs for aftermarket wheels.
Yes lugs can be over torqued.
I'm a bit of a retentive man when it comes to this and I will not use a gun it's hand then torque wrench.
they should be tight, (80-85 ft/lbs ^), but i dont think i would say till you cant do it anymore by hand. if you're using a 1/2" ratchet then that might be about right. if you're using a 4-way however you could very well break off one of the studs. also, not all air guns are the same. setting the impact gun to its highest setting might not be advisable.
I use whatever. Sometimes a 3/8 socketwrench, sometimes a 1/2 impact. It's not like I sit there and hammer it down on the impact, only takes a split second or so.
But I never tighten mine too much, there's no reason to. I hate taking others off that are torqued down like crazy. Never had a problem w/ mine comming lose from the cheapest lug nuts available, to expensive ones, from stock steelies to aftermarket aluminum wheels.
People tent to over torque things thinking that it's going to fall off if they don't. It's like hearing about people snapping or stripping bolts/threads on their valve covers when they can be tightened down with your fingers basically. I personally use a screwdriver w/ 10mm socket on it to do mine just so i never do that ;x
^ w3rd. you can overtighten your lugnuts, but you gotta be a real "musle man". with the right tools you dont have to worry. use an eletric impact and let it max for a couple seconds. really, its not that big of a deal when using good tools.
or if youre tightening lug nuts with a torque wrench, just use standard specs. its kind of a simple theory..
yeah thats the spec most people go by. Honda does about 100 ft lbs. Gray torque stick
seen it MANY times. it sucks!
yup. lol if people have rotas then yes, they NEED to me over torqued haha
^It was a joke lol I dont like rota's very much. When I was in high school 2 years ago every kid and their moms had rotas. I thought the 17's and 18's where annoying till this stage. lol
well the torque value depends on the stud and nuts strength mainly. but when the wheel is a different material (IE Aluminum) it tends to need less as when the rotor heats up the heat passes into the wheel. heat will soften the rim meaning you can actually warp the wheel if the studs are too tight. I know there is more info on this than my $.02 worth
That's what I assumed but a few cars I've had the aftermarket rims made sure to note using MORE ft lbs then OEM.
That's what I'm rather perplexed about.
lol
I know that Blox extended studs need less from what I remember. Not sure if its just cause they are POS studs and break fast, or something else
some manufactures recommend cheking the tourque after 20 miles on aluminom wheels
