Vibration?
I am having a vibration under excelleration (spell check) lol I replaced the axles on both sides, and nither one on the wheels move up and down or side to side but when I turn right the vibration gets a little worse but it goes away when the clutch is pushed in if I remember correctly. Would this be a wheel bearing starting to go bad? I am putting a whole new hub and everything on it tomorrow. And also could worped rotors cause this? Any help would be awesome. Thanks John
could be your motor mounts going bad, could be the clutch too. could be inner tie rods. there are other reasons to get vibrations.
You mentioned you changed your axles. what brand and from where? I've heard nightmares about Autozone axles and them not having the vibration damper that the OEM axles have.
and it's spelled ACCELERATION
sorry if i thread jack,, but i am having almost the same problems...
i recently replaced both my axles and both upper side motor mounts to hasports... i havnt replaced the rear yet... cuz its freaken hard.. but my problem is that under acceleration, i have a vibration aswell... it happens from 25mph to 35mph... anything before or after i dont feel or notice it anymore...
when i spin the wheel there is a slight friction but that could also be the upgraded rotors wobbling ....
what might the problem be.....
it cant be the axles b/c i replaced them, and i repllaced it 2 more times after that thinking it was an unbalanced axle...
its the axles. remaned or new axles have shitty inboard joints.(comes from experience....many axles, many hours put into taking axles apart and compairing them to real oem, also having an axle bind on you at 75mph on the interstate....)
DEVIN22CBR
22
Dec 13, 2003 08:42 PM
