FS : 2.0L B series N/A
Old Sep 23, 2009 | 03:19 PM
hondaboyB18C1's Avatar
Default FS : 2.0L B series N/A
complete B series 2.0L All motor
3000 km's since assembled with new parts!!!!
1996 B18B block
85.5mm x 89.0 mm
Besnon sleeves
bored and decked
Wiseco 8.2 cc pistons
Probe "I" beam rods w/ARP cap screws
Cometic head gasket
Honda GSR timing belt
Honda waterpump
Honda OBD-2 oil pump
Tahio bearings
greddy sandwich plate
B16A head
proted & polisehd
flow bwnched at 286 cfm (in) & 238 cfm (ex)
ARP head studs
supertech stainless flat face valves
skunk2 pro valve springs
skunk2 pro titanium retainers
skunk2 pro cam gears
skunk2 pro 3 camshafts
H22 spring lost motions
CTR valve cover with plug wire cover
sheetmetal intake manifold
68mm tb
RC 550cc injectors
ngk blue wires, plugs
GSR OBD-1 dizzy (new coil, cap, rotor)
Honda thermostat
polished B18B crank
Hytech replica header
XTD 10lb flywheel
all new gaskets and seals when built
will include street tune chip (crome pro)
dynoed on a street tune 230/145
max power at 8900 rpm
rev limit set at 9400
this engine runs and drives awsome, daily drive it mostly
will ship , will work out shippin gwhen sent a zip or postal code
$5000
this is a complete running engine from Throttle body to flywheel including Tri -Y header. it is still in my car. I only drive it 1 or 2 times a week
quicker to email me at eibach2000@hotmail.com
xxjonxx4
Jul 23, 2017 11:22 AM
nickgbmx
Jul 12, 2010 07:33 AM
mozzandherb
May 30, 2010 04:03 PM
Robs_B18c
Dec 31, 2008 04:32 AM
