F22A6 intake manifold
Old Sep 23, 2009 | 10:39 AM
91accord25's Avatar
Default F22A6 intake manifold
I have the F22A1 motor in my car. I was wondering if i got the A6 intake manifold do I need the A6 ECu?
thnkx 4ur time
Old Sep 23, 2009 | 11:20 AM
GhostAccord's Avatar
Default Re: F22A6 intake manifold
If you want the secondary butterflies (IAB) to run via electronic control, then yes you need the PT6. However, if you remove the secondary butterflies or run them with a mechanical/vacuum, then you won't need the PT6 ECU.
Old Sep 23, 2009 | 12:02 PM
Nocture's Avatar
You can also add the A6 cam since it's a bit more aggresive: which means you can use the pt6 at it's potential.
Old Sep 23, 2009 | 12:44 PM
91accord25's Avatar
so A6 cam PT6 ECU to make A6 manifold fit cook. any wiring need to be done?
Old Sep 23, 2009 | 01:11 PM
If your going to run the PT6 you could wire up the IAB solenoid. The wire runs from the solenoid to Pin A17 on the PT6 ECU. Other than that remember your ground connections.
Old Nov 16, 2012 | 08:28 AM
Sac town Racer's Avatar
I have the same motor and doing the same thing and was just wondering if you remove the second set of flaps on the intake manifold would you still get the normal preformance out of it. And also can I swap out a prelude ecu from a f22a1 and do better than the accord ecu
blkekcoupe
Dec 9, 2013 10:54 PM
gutted
Dec 12, 2011 03:12 PM
16v
Jul 24, 2007 04:29 PM
typhoon
Nov 25, 2004 12:28 PM
