hp goal for 470ccm injectors (E85)
Old Sep 23, 2009 | 07:30 AM
Marc_Smith's Avatar
Default hp goal for 470ccm injectors (E85)
Hi folks,
I got 470ccm Injectors on my stock B16 Turbo (8psi, T4 57 trim, made round about 250whp on pump gas) and I want get a new tune on E85.
Are the injectors big enough for this small setup?
Need bigger ones?
What size to be safe?
Thanks for the answers.
Old Sep 23, 2009 | 07:41 AM
non-VTEC's Avatar
Default Re: hp goal for 470ccm injectors (E85)
you will need bigger injectors to run on e85 to make the same power as pump gas. it uses "almost" double the ammount of e85 to run the same power as on pump fuel.
try out some 750cc or larger injectors.
b16b18
Sep 3, 2008 07:38 AM
Tyte-S
Oct 13, 2007 08:32 PM
Sir-Boost-Alot
Feb 4, 2006 12:00 PM
AB16A2T
Aug 30, 2002 10:02 PM
BoostinDC2
Oct 15, 2001 12:35 PM
