gsr trouble starting
Old Sep 23, 2009 | 06:33 AM
gs-R_swap's Avatar
Default gsr trouble starting
so yesterday trying to go home i try to start my car and couldnt get it to start, so i had to push start it. same thing happened this morning, couldnt get it to start so i had to push start it again...my battery has a good load, its not cold here in houston yet, so i dont know....could it be that something in my fuel delivery system is going? could it be that maybe my fuel injectors are clogged and if thats the case could that may be the reason for back firing and slow acceleration when i hit the gas? i dont know, whats ur input on this?
Old Sep 23, 2009 | 06:53 AM
HONDRETTI's Avatar
Default Re: gsr trouble starting
is your fuel pump priming? (turn the key to the on position, listen for a low pop) i ask this bc most of the time with starting issues and our cars its the main relay at fault. cheap, easy fix.
however if youre experiencing back firing and slow acceleration i would assume your distributor has gone bad. check your ecu for any codes such crank angle sensor and tdc error.
Old Sep 23, 2009 | 07:02 AM
gs-R_swap's Avatar
its a new distributor, i dont believe it went bad that soon, i just changed it about 2 months ago, and how does the pump work, does it pump a steady flow or pumps more as you accelerate?
bryondyck69
May 19, 2016 07:44 AM
Tim2179
Honda Civic (2001 - 2005)
Dec 9, 2010 12:18 PM
92jdmxsiteg
May 26, 2007 04:24 PM
Zion-I
Jan 24, 2007 07:34 AM
VTcivicEG
Jul 19, 2004 01:51 PM
